Remove advertisements
Thread: Lever double tool feed for watchmaker lathe
    threesixesinarow's Avatar
    Mar 2018
    threesixesinarow's Tools
    This is a rocker for my little lathe. I copied mostly from pictures of Gortonís Swiss automatic lathes, but itís less finely adjustable and I made it so I can put different things on it, normally tool posts but also things like my screw slotting fixture.
    It has the same function as a cross slide with front and rear tools on a regular screw machine or plain lathe, and like those is limited to in-feeding, but instead of sliding on ways it rotates about 45į on a journal that clamps around the bed. Each side has a small slide to set cut depth relative to the fixed stops underneath, with t-slots for mounting tools that allow some individual sideways adjustment. Springs center it when itís not cutting.
    Itís a 3/16Ē tool in the video.
    Lever double tool feed for watchmaker lathe-wmlr01_inuse.jpg Lever double tool feed for watchmaker lathe-wmlr04_gortonphoto.jpg
    Lever double tool feed for watchmaker lathe-wmlr02_onbench.jpg Lever double tool feed for watchmaker lathe-wmlr03_drawing.jpg
  2. The Following 4 Users Say Thank You to threesixesinarow For This Useful Post:
    Jon (12-14-2018), PJs (12-17-2018), Seedtick (12-14-2018), stuffucanmake (12-16-2018)
    Content Editor DIYer's Avatar
    Thanks threesixesinarow! We've added your Watchmakers Lathe Dual Tool Holder to our Lathe Accessories category,
    Post your reply!
