anthonyget (Nov 6, 2020), Beserkleyboy (Nov 12, 2018), editor@glue-it.com (Jun 7, 2022), high-side (Feb 9, 2019), Jon (Nov 12, 2018), mklotz (Nov 12, 2018), PJs (Nov 18, 2018), ranald (Nov 13, 2018), Seedtick (Nov 12, 2018), Shanty (Nov 18, 2018)
Great material choice. This is one of the nicer plumb bobs we've seen, and we have 13 other ones listed: Homemade Tools: plumb bob - HomemadeTools.net
HomemadeTools.net founder (2012) and CEO
Join thousands of us, and start building your own tools today.
One of the more awkward jobs to do accurately is marking the exact point over which a plumb bob hangs. Using the actual tip of the bob can damage it, especially if marking concrete, and is just, well, brutish.
One approach I've seen to this problem is a bob shaped like a horizontal washer with four arrow points that point inward to the center of the annulus. After the bob comes to rest it's lowered carefully onto the stuff to be marked and a pencil mark made at the center of the four points. While it might work, it seems a bit gimmicky plus it wouldn't work well if the surface to be marked is angled.
IMO, a much better solution would be a plumb bob with interchangeable points. Unscrew the normal, sharp steel point and fit a thin, ultra fine point Sharpie. Then simply lowering the stabilized bob onto the surface would leave a precise mark.
Maybe I'm overthinking things - a machinist designing a push broom. Perhaps nobody needs to mark the sub-bob point that accurately.
Thank you Jon! I don't know if you saw the video, but I'm sure that you'll like this also
Attachment 26326 Attachment 26327 Attachment 26328
this was my contribution for Keith Fenner's WIYB 2015
Cheers
Jimmy
