Free 50 Best Homemade Tools eBook:
Remove advertisements
Thread: Measuring acute angles accurately
    mklotz mklotz's Avatar
    In a previous post...
    Bending Strap to Angles Greater than 90°
    I mentioned a method for using three, equal diameter, rods or disks to measure an obtuse angle accurately.
    The same method can be applied to acute angles, although the mathematical relation is slightly different than that for the obtuse case.
    The attached diagram should make the procedure clear. 'D' is the diameter of the rod/disk. Theta is the angle to be measured.
    Home Shop Freeware
  2. #2
    Paul Jones's Avatar
    May 2014
    Yorba Linda, California
    Hi Marv,
    How do you typically preform the measurements of the distance H when the opening distance is very small? Do you slide in gage blocks until you find one that just fits in?
    Thanks,
    Paul
  3. #3
    Hi Marv,
    How do you typically measurement of the distance H when the opening distance is very small? Do you slide in gage blocks until you find one that just fits in?
    Thanks,
    Paul
    Admittedly, I've only used this technique a few times but, yes, gauge blocks are the tool of choice.
    Post your reply!
    Join 33,912 of us and get our 50 Must Read Homemade Tools eBook free.
    Home Shop Freeware
  4. The Following User Says Thank You to mklotz For This Useful Post:
    Paul Jones (01-04-2018)
