1 Attachment(s)
Mill Tramming Tool
Here is a tool I built a few years ago when we were doing a lot of work with the Mill at the shop. Pretty simple contraption, really. ...just a few odds and ends from the scrap pile, a couple of HF dial indicators and a few set screws.
I cleaned up the stainless shaft, drilled a few holes in the aluminum rod, drilled and tapped a couple of holes for set screws. I also tried to whipped up a jig for letter stamping, but didn't have the best luck (if you look closely, you can see a little double striking). I then chamfered the edges, hit the whole thing with a little scotch brite, and then threw it all together.
Now, whenever I have to square things up, I have a tool to do it. ...And all it took was a little effort on an otherwise uneventful Saturday afternoon.
These have been done before, so it's not like it's anything all that new. Dale from Metal Tips and Tricks did a great video on building and using one of these, that would be a great resource for anyone interested in making one of their own.
Thanks TomBuildsStuff! We've added your Mill Tramming Tool to our Measuring and Marking category,
as well as to your builder page: TomBuildsStuff's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-mill-tramming-tool-6">
<img src="/uploads/213202/homemade-mill-tramming-tool-6.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-mill-tramming-tool-6">Mill Tramming Tool </a>
<span> by <a href="http://www.homemadetools.net/builder/TomBuildsStuff_2">TomBuildsStuff</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/mill'>mill</a>, <a href='http://www.homemadetools.net/tag/dial-indicator'>dial indicator</a>, <a href='http://www.homemadetools.net/tag/tramming'>tramming</a> </div>
</div>
</div>
</div>
