Remove advertisements
Thread: Mini Lathe Carriage Gibs and Travel Handle Improvement
    jjr2001's Avatar
    jjr2001's Tools
    Similar to other mods of the Mini Lathe carriage gibs. I used 3/4" wide by 5/16" thick brass stock 6" long
    to make the new gibs. Simple attachment using the original retaining bolts. I machined them to be undersize
    and then used brass shim stock to get the proper fit with the screws snugged up. I have adjusted them once
    since installing them. (about 2 years). All that was needed was to increase the tightness of the bolts.
    With the added 2 inches in length over the standard gibs the carriage is less likely to lift or tilt. So far I like the
    mod and find that my carriage is much more rigid than before the mod.
    I still have to remove the carriage to adjust them but that is an easy process.
    The carriage Handle: Previously I had replaced the plastic handle with steel which was nice but now, same as before but worse, the off balanced handle would cause a "jump" in the carriage travel when using the lead screw to move the carriage. This causes a flaw in the finish as the part is turned. To prevent this I added another steel handle to balance the first one and now the carriage moves smoothly. I like the extra handle for control of the carriage. My finish is now much better than it was prior to the mod.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Mini Lathe Carriage Gibs and Travel Handle Improvement-img_1484b-copy.jpg   Mini Lathe Carriage Gibs and Travel Handle Improvement-img_1486b-copy.jpg   Mini Lathe Carriage Gibs and Travel Handle Improvement-img_1487b-copy.jpg
  2. The Following 6 Users Say Thank You to jjr2001 For This Useful Post:
    NortonDommi (05-27-2018), Paul Jones (01-18-2018), PJs (01-20-2018), Saxon Violence (01-20-2018), Seedtick (01-18-2018), Toolmaker51 (01-20-2018)
    Content Editor DIYer's Avatar
    Thanks jjr2001! We've added your Mini Lathe Carriage Gibs to our Lathe Accessories category,
    jjr2001 (01-23-2018)
    Thanks jjr2001! We've added your Lathe Travel Handle Improvement to our Lathe Accessories category,
    Post your reply!
