Results 1 to 6 of 6
Thread: Mini Vise Restoration
    Supporting Member Make Everything's Avatar
    Sep 2017
    CN
    Make Everything's Tools
    I bought an old mini bench vise, it is not an antique, but it is not very common.
    I restore it,And made a little modification.
    video in here
    Welcome to my YouTube Channel: www.youtube.com/channel/UCEoFlPTBSPpRAH05kPiSx_Q
  2. The Following 12 Users Say Thank You to Make Everything For This Useful Post:
    almarghi (Jul 13, 2018), PJs (Jul 15, 2018), ranald (Nov 2, 2018), rlm98253 (Nov 1, 2018), rossbotics (Jul 15, 2018), Saxon Violence (Jul 13, 2018), Scotsman Hosie (Jul 21, 2018), Seedtick (Jul 13, 2018), sossol (Jul 13, 2018), techcollect (Nov 2, 2020), Toolmaker51 (Nov 1, 2018), volodar (Jul 16, 2018)
    Supporting Member Drew1966's Avatar
    Oct 2016
    Nice. But two possible improvements.
    Why use a wire brush when it actually removes metal?
    A heat gun would remove the paint/putty with out removing metal.
    Also, chemical rust removal leaves rust in any cracks whilst electrolysis removes every single molecule of corrosion.
    Over all though, a wonderful restoration.
    Thanks Make Everything! We've added your Vise Restoration to our Vises category,
    as well as to your builder page: Make Everything's Homemade Tools. Your receipt:
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Well Done, Make Everything! That is a fine little vice and like the tiny anvil on the back. Looks to have a substantial carrier for a small vice and adding the brass washers is something I do also. A trick I use on stuck flat heads is to heat it slightly and use a Hand Impact driver...hasn't failed me yet. Don't know if you have them in CN but they've been around for 50 years, and pretty reasonably priced. You could also save the table mount by creating a washer on the lathe with a loose clearance hole for the screw tip and then pein it over. That way you could use it if you need to.
    Thanks for sharing the restoration with us. I love saving these types of tools...a shop can not have too many vices!
    PJ
    Mark Twain
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    Quote Originally Posted by Drew1966 View Post
    Chelating is a lot slower but also works fine instead of the wire brush on rusty areas : use 10 parts of water to one part molasses. will not remove sound painted paint (without rust under). Parts must be quickly cleaned after removal or rust is accelerated..Lovely little vice.
    Dec 2017
    NeiljohnUK's Tools
    Nice work, good use for cleanroom floor tiles too.
