Remove advertisements
Results 1 to 8 of 8
Thread: MOBILE DRUM SANDER TROLLEY
    ranald's Avatar
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    When my 19_38 SuperMax drum sander arrived, I had a spot planned for it but found that it was unsuitable due to being fixed to a wall.
    I had some Brownbuilt metal shelving in another shed & thought at 900mm high it would work well.
    I use some for sharpening & mitre sawing & that height is comfortable for me. It was too awkward to use after attaching 100 mm castors & reducing the height a bit for the sanders ends. I also fitted a sheet of plywood over some checkerplate foam rubber to dampen bumps & noise generated by the steel bench. A piece of scrap aluminium was used to brace the open front.
    Attachment 29283
    Therefore it was on to plan B.
    I decided that 230mm should be cut off the cabinet (& keep the finished height a little below my tablesaw height) so did that. To avoid jaming I inserted tiling wedges as I cut.
    MOBILE DRUM SANDER TROLLEY-rsz_dsc_0049-1-.jpg MOBILE DRUM SANDER TROLLEY-rsz_dsc_0050.jpg
    I also left the front two corners till last & cut them with a hacksaw. I had thought of using a G cramp spaced over the hearby cut but decided against that.
    MOBILE DRUM SANDER TROLLEY-rsz_dsc_0055-4-.jpg MOBILE DRUM SANDER TROLLEY-rsz_dsc_0054-4-.jpg
    I replaced the top with foam & ply & it now it is much easier to manage. The final height is approx 870mm.
    I have had a minor irritating issue with this excellent sander and will cover that in a different post.
    MOBILE DRUM SANDER TROLLEY-rsz_dsc_0058-1-.jpg MOBILE DRUM SANDER TROLLEY-rsz_dsc_0059.jpg
    Cheers & happy woodworking
    Ranald
  2. The Following 2 Users Say Thank You to ranald For This Useful Post:
    Altair (04-16-2019), PowerMk (04-20-2019)
    Content Editor Altair's Avatar
    Thanks ranald! We've added your Drum Sander Trolley to our Dollies and Stands category,
    as well as to your builder page: ranald's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to Altair For This Useful Post:
    Beserkleyboy (04-19-2019)
    Beserkleyboy's Avatar
    Aug 2014
    Beserkleyboy's Tools
    Ranald, WOO HOO!! Flash sander, mate...I was too cheap to part with the $$, hence my home built version. Good one.
    Jim
  6. The Following User Says Thank You to Beserkleyboy For This Useful Post:
    ranald (04-19-2019)
    ranald's Avatar
    Jan 2018
    ranald's Tools
    Quote Originally Posted by Beserkleyboy View Post
    Jim
    Thanks Jim, I was going to make & eventually found some plans for a flat table drum sander but after trying one at my local woodies club I changed my mind and promised myself one of these when I had the loot (wish I had one 40 years ago:lol). The flat table ones are good but really, really slow and can't be used as a thicknesser. The con for the 19_38 & other similar ones it the limitation of height, but in those cases (excuse pun) I use an orbital hand held job.
    Can you show your version or is it in/on HMT already- I did a search, but not too flash on the laptop.
    Cheers
    Ranald
    Aug 2014
    Mate, yes it's in here, just click on 'awards showcase' box under my workshop pic. Cheers
  9. The Following User Says Thank You to Beserkleyboy For This Useful Post:
    ranald (04-20-2019)
  10. #6
    ranald's Avatar
    Jan 2018
    ranald's Tools
    Ta! I remember your post now & did a reply there. I'm learning more about this "website" or whatever it 's official description is: I often search, obviously incorrectly, to no avail and end up going on with requisite duties like housework (my partner works full time). It has lots more than meets the eye: transforming me! A bit like Excel the more I play the more I find. I need more hours in the day= no chronic fatigue would allow me to better leverage my time.LOL
    Cheers,
    Ranald
  11. #7
    Aug 2014
    Ranald
    Tell me about your cyclone I see in the background
    Jim
  12. #8
    ranald's Avatar
    Jan 2018
    ranald's Tools
    Ranald
    Jim
    Hi Jim,
    It's an Oneida, Super Dust Deputy from North America: (I really like US, Canadian. UK, NZ, German, Swiss and Oz made stuff). There is some detail in my HMT post for the mobile dust extraction unit, but here is some more info. I purchased from Carbatec for $500 but worth it as my homemade one was thrown out yonks ago as I just couldn't get it right: some might FITH: maybe should have tried just either metal or wood instead of combining materials.
    Had a couple of minor issues with fitting. There is a 5" inlet and after declining my 200 litre flat top plastic drum, I went for a smaller, lighter when filled, shorter (to avoid my overhead storage as I needed mobility) drum which did not have a flat top so made a spacer type union from masonite using a router.
    Pic showing inlet for template with union
    for attaching base of cyclone to drum top.
    That was then siliconed & bolted to the clip off top of the drum and looks like this
    As the Oneida has a 6" inlet, & doesn't come
    with a step down I bought 6"/5" one from Carbatec.
    It of course didn't fit so used some 6" pvc down/storm pipe
    which worked fine. Siliconed on for dust proofing and strength. MOBILE DRUM SANDER TROLLEY-rsz_dsc_1274.jpg
    Next minor issue was the connection to my 1992 extractor.
    The metal one that came with cyclone or I bought with it wouldn't
    slot together so to make them align I made this connector
    by cutting some more 6" pvc and joining with long alloy
    rivets and more silicone. Worked a treat. MOBILE DRUM SANDER TROLLEY-rsz_dsc_1275.jpg
    I have a smaller plastic Dust Deputy with similar minor
    challengers but have not really looked at as yet due to
    all the other stuff going on.
    I had to get out the house away from SWIBO, and had
    some fun making an Angry Bear for my regen rain forrest
    & was told it looked nothing like a grizzly so it is a really
    big Boo Boo. LOL. No green hat/tie and only 5'4".
    P.S. I did not earth the very short lengths of PVC.
    Cheers, I hope this helps & brings a grin
    Ranald
    Post your reply!
