I'm a sucker for multipurpose tools so when I saw the double-headed ratchet wrench ( item#67993 ) at Harbor Freight, I just had to have one. It has a 1/4" drive on one end and a 3/8" wrench on the other end. It's shown at the bottom in the picture.
But, then, strolling through Amazon, I came across this...
https://www.amazon.com/dp/B01LWUMPBB...ams_ad_dp_ovrl
1/4, 3/8, and 1/2" ratchet in one wrench plus it has a hex-drive for those ubiquitous screwdriver bits. It's shown at the top.
The convenience of wrenches like this is having two different size (e.g. 1/4 and 3/8) sockets available by simply flipping the wrench over. Even better, I find, is having the ability to mount two (or more) sockets of the same size by using size adapters, some of which are pictured.
If all you need is the 1/4" and hex driver capability, I can highly recommend this little gem...
https://www.amazon.com/Powerbuilt-94...2Bratchet&th=1
It's small enough (3.5" long) to fit in a pocket and great for getting into tight places.
Attachment 21167
