Results 1 to 7 of 7
Thread: Multi V-Block Plans available
    jjr2001's Tools
    I used Doug Ross's plans for the basis of my V-block. My vise for the mill is a 4" width so his plan looked quite good.
    Here are Doug's plans:
    http://www.homemadetools.net/forum/m...8657#post26049
    I made changes to the plans since I wanted a "soft" V-Block since I plan on using it with
    aluminum,brass and plastic. I also "cheated" on the vertical grooves since I had a nice new
    carbide 2 flute router bit with a nice 45 degree angle. Much faster than the way I made the long grooves.
    I also have two nice V-Blocks that I set vertical in the mill for working on the end of parts. What I really
    needed was the long grooves and that is why I built Doug's plan.
    For the long grooves I used an end mill and flipped the part 180 deg to complete the opposite half. That
    works good but it does take a bit longer and the part is a bit harder to hold for the vertical Vees.
    I tried not to cut too deep since it is just aluminum but when clamped in the vise it should work fine.
    Thanks to Doug for the fine set of prints and instructions for making a very useful tool for the shop.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Multi V-Block Plans available-img_2145.jpg   Multi V-Block Plans available-img_2146.jpg
  2. The Following 10 Users Say Thank You to jjr2001 For This Useful Post:
    Big-Pete (Nov 6, 2020), high-side (Feb 14, 2019), Home-PC (Nov 21, 2022), Jon (Nov 14, 2018), MaxV70R (Nov 18, 2018), PJs (Nov 18, 2018), rossbotics (Nov 15, 2018), Seedtick (Nov 14, 2018), Tonyg (Nov 15, 2018), Toolmaker51 (Nov 14, 2018)
    Very nice work. As long as you have the router bit, you might want to consider some very shallow V-grooves to hold material with a very small diameter. As I can testify, such are very handy for jobs like shortening 2-56 screws.
    Home Shop Freeware
  4. The Following User Says Thank You to mklotz For This Useful Post:
    jjr2001 (Nov 14, 2018)
    jjr2001's Tools
    Thanks Marv, excellent idea. Still plenty of room for more Vee's.
    Cheers, JR
    Dec 2013
    Florida
    rossbotics's Tools
    Nice work JR and Thank You
    That V-Block has came in handy so many times I couldn't count them.
    Thanks Again Doug
    Comments are always welcome
    Doug
  7. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    jjr2001 (Nov 15, 2018), PJs (Nov 18, 2018)
    Nice work! Since you posted your build from plans, you get another free set of plans of your choice. Let me know which ones you want and I'll send them out to you.
  9. The Following User Says Thank You to Jon For This Useful Post:
  10. #6
    jjr2001's Tools
    Thanks Doug and Jon, I can always use another set of plans!
    Cheers, JR
  11. #7
    Thanks jjr2001! We've added your Multi V Block to our Machining category,
  12. The Following User Says Thank You to DIYer For This Useful Post:
    jjr2001 (Nov 17, 2018)
