Results 1 to 10 of 15
Thread: Need help with sprocket ratios?
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    I have a 12 volt dc motor that has a gear head on it and turns at 41 rpms . on the motor shaft i have put a 11 tooth gear and on the other shaft is a 60 tooth sprocket which gives me 5.5 rpm. I need 1 or 2 rpm at most what should I do?? can I put a 30 tooth sprocket on the motor will this give me the desired rpm or is the torque wrong.Should I get a gear head reducer and put it in line with the gears I have now. what is the best??
    Thanks for looking. L@@KING.
  2. #2
    Mar 2015
    Boone, NC
    I've been using this for pulleys. Maybe it will help.
    Pulley Calculator. RPM, Belt Length, Speed, Animated Diagrams
  3. The Following 3 Users Say Thank You to GlennR For This Useful Post:
    Captainleeward (Mar 7, 2015), PJs (Jan 25, 2016), Toolmaker51 (May 24, 2016)
    Jul 2014
    I can't find a tooth reference to rpms :O( Nice of you to mention it thanks...:O)
    Mar 2015
    Boone, NC
    I reread your question. Since it's a DC motor, why not just add a speed control and adjust the speed by turning the knob down?
    Variable speed is the beauty of DC motors, right?
    Btw, here's a site for helping choose sprockets for motorcycles. I doubt it's useful for this, but might be handy sometime.
    http://www.gearingcommander.com/
  6. The Following 2 Users Say Thank You to GlennR For This Useful Post:
    Captainleeward (Mar 12, 2015), Paul Jones (Oct 1, 2015)
    Jul 2014
    I will check the specks for the motor and see if that is possible THANKS for your input.
    I will let you know the out come....:O)
    Jul 2014
    Well that was a good idea but only starts at 41 rpm won't go down in rpm.
  9. #7
    Good, informative sites, GlennR. Although it didn't help the captain much, I'm sure it's going to be a useful reference for someone in the future.
  10. The Following 2 Users Say Thank You to DIYer For This Useful Post:
  11. #8
    Mar 2015
    Boone, NC
    1 RPM is really slow. You didn't say the size of the motor, but I'm assuming it's not very large since it's 12V.
    You might be better off shopping for a gear motor that's already mated & sized to work together. I used to shop at Surpluscenter.com a bit. Sometimes they'd have odd assemblies that sound like what you are looking for. Sometimes odd things like that are cheaper than trying to find good deals on the separate components.
    What's a "stepper motor"? That sounds like a slow rpm motor, but I can't remember what they are for. Might be something to look at.
  12. The Following User Says Thank You to GlennR For This Useful Post:
  13. #9
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Lightbulb
    Stepper motors are often found in old printers or many of the cheap Chinese sites for a penny each. They are popular for use in DIY CNC machines, 3D printers or plotters and the like.
    They might be perfect for the job.
    Try here
    Regards
    Doc
  14. The Following 2 Users Say Thank You to Doc For This Useful Post:
    Captainleeward (Mar 12, 2015), Jon (Mar 10, 2015)
  15. #10
    Jul 2014
    The size of the motor is 1/4 hp and is as big as a car starter you can see one on my bead roller here.
    the easiest solution is to use a larger gear on the motor side. but I don't know if that would do the trick. vurently there is a 60 tooth sprocket on the shaft and a 11 tooth sprocket on the motor.
    this gearing is 5.5 rpms.
    Next best one is to put a reducer gear box on the shaft to reduce the ratio further.
    this motor is 41 rpms I need 1 or 2 rpms. The shaft I'm turning is balanced and does not require much torque.
    Need help with sprocket ratios?-023.jpgNeed help with sprocket ratios?-022.jpg
