Remove advertisements
Results 1 to 10 of 10
Thread: Newbie to site(Belt Grinder)
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    First post newbie. I just finished top part my 2" x 72" belt grinder. It not pretty but it runs smooth and grinds even better. I built it out of a treadmill motor and a motor control I got yers ago for a pitching machine build but ended up getting a good deal on one I found on CL.
    I made everything except the wheels and platen and the build is all repurposed materials.
    A) The Steel is all 1/4" or 3/8" structure steel to keep from flex and vibrating
    B) The Adjustment Idler wheel is mounting bracket to mount computer monitor to the desk and worked perfect(salvaged)
    C) The D plates are 1/4" aluminum(salvaged)
    D) The Plate rest is 2 x 3/16" aluminum(salvaged)
    E) The Adjustment arm for the plate came of a gun shooting plexi-glass platform I built for my sons wheelchair. I wanted to incorporate something that reminds me of him since he passed away a few years ago.
    F) The plate is designed to angle in both directions since I can run the grinder forwards and backwards, then I use a digital angle meter to set the angle. The plate is also designed to slide off for flat grinding as well.
    G) It uses a gas spring to maintain tension and it designed to simply pull down and slide the belt off.
    H) The motor is controled speed by a potentiometer mounted on the control box.
    I) I mounted a blower to help keep platen cool powered by an old 24 volt laptop power supply.
    J) The Cabinet is salved pallet from work and the cabinet dolly someone threw away when they moved down the street.
    K) Total cost $275
  2. The Following 8 Users Say Thank You to Bevoblood For This Useful Post:
    Jon (05-22-2018), Neil Jensen (05-22-2018), NortonDommi (05-24-2018), olderdan (06-04-2018), PJs (05-23-2018), rossbotics (05-24-2018), Seedtick (05-22-2018), Tuomas (05-22-2018)
    Soikkeli Tuomas's Avatar
    Jyväskylä Finland
    Tuomas's Tools
    That seems to be well thinked. Extra + from the dust blower.
  4. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (05-23-2018)
    Leo in Saint Charles, Mo. Toller's Avatar
    May 2015
    Saint Charles, Missouri
    THought you had made a whole herd of grinders
    Would love to see you post individual photos. Can't get a good grasp with the smaller images. Nicely done.
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    Reposted Grinder pics
    Newbie to site(Belt Grinder)-r-side-view-close-up-sm-.jpg Newbie to site(Belt Grinder)-20180522_204035-1-.jpg
    Newbie to site(Belt Grinder)-20180522_204227-1-.jpg Newbie to site(Belt Grinder)-20180522_204709-1-.jpg
    Newbie to site(Belt Grinder)-20180522_204439-1-.jpg Newbie to site(Belt Grinder)-20180522_204900-1-.jpg
    Attached Thumbnails Attached Thumbnails Newbie to site(Belt Grinder)-belt-grinder-front-view-sm.jpg   Newbie to site(Belt Grinder)-belt-grinder-side-view-sm.jpg   Newbie to site(Belt Grinder)-front-view-close-up-sm-.jpg   Newbie to site(Belt Grinder)-l-side-close-up-sm-.jpg
  7. The Following User Says Thank You to Bevoblood For This Useful Post:
    PJs (05-23-2018)
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    Reposted pics Toller
  9. The Following 2 Users Say Thank You to Bevoblood For This Useful Post:
    Jon (05-23-2018), PJs (10-14-2018)
  10. #6
    ncollar's Avatar
    Oct 2012
    Now that is a belt sander, very nice and you will get plenty of satisfaction out of it.
    Very nice.
    Nelson
  11. #7
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    Thanks Mr. Collar it was a lot of hard work and redesign along the way. It is the combination of several ideas and grinders I took inspiration from.
  12. The Following User Says Thank You to Bevoblood For This Useful Post:
    PJs (10-14-2018)
  13. #8
    Content Editor DIYer's Avatar
    Thanks Bevoblood! We've added your Belt Grinder to our Grinding category,
    as well as to your builder page: Bevoblood's Homemade Tools. Your receipt:
  14. #9
    Aug 2016
    wizard69's Tools
    Quote Originally Posted by Bevoblood View Post
    It is certainly different from the normal square wheel. Was the idea here to be able to do slack grinding and square wheel grinding with out changing the setup? Or possibly a space savings measure?
    Also it is kinda hard to tell from the pics but it looks like you have a cooler blowing on the back side of the platen? I think this is the first I've seen something like this.
  15. #10
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    Wiz I just kind of took ideas from several types of grinders 2,3 and 4 wheel types and put them in mine,I took little things I liked about each design and incorporated them into something I liked. I wanted to be able to have it for multiple uses. I can take the front attachment plate off just by sliding it off easily and it makes it easier to square/flat grind sometimes. I can easily slide the D plate back to slack grind. I can easily slide attachment plate back on throw a quick digital angle meter on it and get the exact angle I want to put on a work piece. I can also quickly change the direction of the motor on the back of the control box since the power goes in via banana plug so just flip the cables in 5 seconds and I can put an angle on the plate in the other direction. This way I am not looking down into the workspace area. I can now easily see it since the work piece since it is out front now and not looking down into the workspace.
    Yes that is a 24 volt computer blower fan, the switch is small black box mounted with velcro on the side of the upright that is plugged into a 24 volt wall supply mounted with velcro on the back of the upright. It does a good job keeping the platen cool since it is a blower type fan and not a regular type fan and keeps the dust out of the way.
    Post your reply!
  16. The Following 2 Users Say Thank You to Bevoblood For This Useful Post:
    Jon (06-04-2018), PJs (10-14-2018)
