Results 1 to 7 of 7
Thread: Offset Square
    Dec 2013
    Florida
    rossbotics's Tools
    Offset Square
    Many times I wished I had something to locate the edge of a small piece vertically in the milling machine vise, if a part isn’t large enough to locate itself from a previously machined edge on the bottom of the vise or parallels then you have to take other measures to insure squareness of your part.
    I came up with this idea of an offset squaring devise, something that had a thin blade that would fit right into the milling machine vise so I could rest my part up against the blades edge therefore squaring my part, to give an example of how to use this tool just think of standing a pieceof 1/4" X 1/4” square steel on its end 4” long, it’s not going to be vertical just sitting on its end even if you machined that end, it doesn’t have enough surface area to locate itself, it still needs a little help.
    This tool was made in three pieces sandwiched together with three 1/4"dowel pins and three 1/4"socket head cap screws, it was ground all over before assembly then put together and just the critical surfaces reground.
    I have included some photos of the tools assembly along with photos of using the tool.
    As always thanks for looking and happy machining
    Doug
    Attachment 26399 Attachment 26400 Attachment 26401
    Attachment 26402 Attachment 26403
    Comments are always welcome
    Doug
  2. The Following 14 Users Say Thank You to rossbotics For This Useful Post:
    Bony (Nov 22, 2018), darkoford (Nov 20, 2018), Home-PC (Mar 19, 2021), HUMARIA (Feb 19, 2019), LMMasterMariner (Nov 21, 2018), Metallurg33 (Nov 24, 2018), Miloslav (Dec 17, 2018), Paul Jones (Nov 18, 2018), PJs (Nov 21, 2018), Scotty1 (Nov 20, 2018), Seedtick (Nov 20, 2018), Shanty (Nov 20, 2018), threesixesinarow (Nov 18, 2018), Toolmaker51 (Apr 7, 2019)
    Oct 2012
    Doug
    Love the square, just what I need.
    Nelson
    Thanks rossbotics! We've added your Offset Square to our Measuring and Marking category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
  5. The Following User Says Thank You to DIYer For This Useful Post:
    rossbotics (Nov 21, 2018)
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Nice tool to have if you don't have 2 machinist's squares. I am using 2 machinist's squares clamped with c clamp.
    Attached Thumbnails Attached Thumbnails Offset Square-clamp-machinist-squares-setup.jpg
  7. The Following 3 Users Say Thank You to LMMasterMariner For This Useful Post:
    Home-PC (Mar 19, 2021), Jon (Nov 21, 2018), Miloslav (Dec 17, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Thanks Nelson, just what I needed too LOL
    Doug
    Doug
    Dec 2013
    Florida
    rossbotics's Tools
    Hey Mariner that works too, as long as it gets the job done !
    Doug
    Doug
  10. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (Nov 21, 2018)
  11. #7
    Dec 2018
    SASocal's Tools
    Quote Originally Posted by LMMasterMariner View Post
    Would this work instead of the 2 t squares ?
  12. The Following User Says Thank You to SASocal For This Useful Post:
