Remove advertisements
Thread: One liners
    mklotz mklotz's Avatar
    One liners
    This style of electrical grounding clamps make good lathe dogs. All you need to do is add a short driver rod to fit against the chuck jaw.
    One of those small adjustable Dremel chucks fitted to a length of tube with a spinner makes a neat little pin vise.
    A small magnifying lens mounted to your prick punch will make marking out a bit easier. Use a bit of heavy copper wire as the mount to allow for fine tuning the focus.
    A sawed-off toothbrush head held to the carriage with a magnet will keep the lead screw free of swarf.
    A tea ball makes a great constrainer for cleaning small parts in solvent.
    Fitting your fishtail gage with a tiny V-block will make holding it square to the workpiece much easier.
    Liquid electrical "tape" applied to tweezer ends will make them tacky and prevent small parts going "sproing".
    Soft, self-adhesive foam weather stripping applied at the edge of the workbench will make a forearm-friendly fence to prevent small parts rolling off.
    Home Shop Freeware
  2. The Following 9 Users Say Thank You to mklotz For This Useful Post:
    jjr2001 (11-01-2018), Jon (09-01-2015), kbalch (09-01-2015), Make Everything (11-05-2017), oldcaptainrusty (10-18-2017), PJs (09-02-2015), rendoman (08-06-2016), rlm98253 (11-02-2017), Toolmaker51 (03-14-2017)
    Jun 2012
    Clermont, FL
    Thanks Marv! I've added your Lathe Dogs, Lead Screw Cleaner, Pin Vise, and Punch Magnifier to, respectively, our Lathe Accessories, Vises, and Measuring and Marking categories, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    Jun 2012
    Clermont, FL
    Thanks Marv! I've added your Small Parts Cleaner, Fishtail Gauge, Tweezer Modification, and Workbench Modification to, respectively, our Cleaning, Measuring and Marking, Workholding, and Workbenches categories, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    Post your reply!
