Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: One-man off-grid log cabin build with homemade tools - video
    One-man off-grid log cabin build. Kinda like a Dick Proenneke thing, but less bucolic, and more instructional, with homemade tools and techniques.
    4:00 video:
    Rough guess: more than half of our members maintain a "build a log cabin" dream. I know I do.
    Debarking logs with a pressure washer - GIF
    Logging truck rear steer dolly - GIF and photo
  2. The Following 12 Users Say Thank You to Jon For This Useful Post:
    baja (Dec 18, 2018), clydeman (May 5, 2020), hansgoudzwaard (Dec 17, 2018), high-side (Dec 17, 2018), HobieDave (Apr 5, 2020), KustomsbyKent (Dec 18, 2018), oldcaptainrusty (Dec 17, 2018), PJs (Dec 18, 2018), Saxon Violence (Dec 20, 2018), Seedtick (Dec 17, 2018), Sprig1 (Dec 19, 2018), Toolmaker51 (Dec 18, 2018)
    I do; but I'll prefer brick...cause I'm not interested in moving again. Too many things I like are real tough off-grid.
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    I’m so jealous of people that seem to be cyborgs. I don’t know how a single human being can do so much work. It is just something I don’t have in me. I’ve tried many times but I just don’t have whatever special sauce people like this have.
    New update today, with plenty more homemade tools.
  6. The Following 5 Users Say Thank You to Jon For This Useful Post:
    KustomsbyKent (Jan 2, 2019), PJs (Jan 2, 2019), Scotty1 (Jan 1, 2019), Seedtick (Jan 1, 2019), will52100 (Jan 1, 2019)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Really liked that Bearing Race draw knife!
    Mark Twain
    Fresh episode. I like the log ramps he uses to send cut logs to the cabin. And the various guides for cutting the logs too. 10:05 video:
  9. The Following 7 Users Say Thank You to Jon For This Useful Post:
    Clockguy (Feb 3, 2019), high-side (Feb 2, 2019), oldpastit (Feb 3, 2019), PJs (Feb 2, 2019), rlm98253 (Feb 2, 2019), Seedtick (Feb 2, 2019), Tonyg (Feb 3, 2019)
  10. #7
    Jun 2018
    WOW, thank you EXCELLENT
    4:00 video:
    http://www.homemadetools.net/forum/d...151#post120966
    http://www.homemadetools.net/forum/l...3540#post99383
    GREAT video and life style! All that's needed now is a water wheel, a line shaft, and an of the grid gun smithy. Unregistered of course.
  11. #8
    Max Egorov asks whether to depend on wedge or lever to raise header at occasion of installing pin hinged door. Found link and he'd acquired plenty of responsible replies.
    My experience says plan to implement both. I wedge and lever frequently, yet they don't seem interchangeable.
    Working against considerable weight is a lot about timing and agility. The advantage in levers gains by distance from fulcrum at operators end, and/or reducing space from load to pivot. Power diminishes with each degree higher initial position.
    So, I use wedges of two varieties to 'park' a load, while preparing a new bite for the prybar, depending on shape/ weight of object. Version 1 are simple inclines, which allow minute increments of adjustment. Oak from scrap pallets for larger sizes, aluminum for smaller; both have tendency to grip floor and object as they are soft without deforming. Version 2 are made simultaneously, two matching wedges just like adjustable parallels. I use a short [6'] fiberglass fishing rod blank to manipulate wedges while I manage the prybar. By combining the two, takes advantage best qualities both offer.
    What I do avoid is knocking wedges in to impart lift, often become increasingly hard to remove. When called for though, I use what pipefitters use, flange separators, quite similar what used by timber cutters known as 'felling wedges'.
    Since I retain all my limbs and respective appendages, system works well. Especially that nearly everything I do is unaided.
  12. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Feb 5, 2019)
  13. #9
    The same guy posted a video of a homemade wire clamping tool, plus you get to see more shots of his cabin. 10:35 video:
  14. The Following 8 Users Say Thank You to Jon For This Useful Post:
    baja (Oct 23, 2019), high-side (Oct 23, 2019), Macca Boy (Oct 22, 2019), n9dug (Oct 23, 2019), NortonDommi (Oct 31, 2019), rlm98253 (Oct 22, 2019), Toolmaker51 (Oct 28, 2019), volodar (Oct 26, 2019)
  15. #10
    The more of these wire clamping tools I see being posted here the more I think I need to take the time and build one for myself.
  16. The Following User Says Thank You to Frank S For This Useful Post:
