Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 40 of 44
Thread: Packaging roller bearings - GIF
  1. #31
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    baja (Apr 25, 2019), jimfols (Apr 23, 2019), Moby Duck (Apr 24, 2019), Scotsman Hosie (Apr 24, 2019), Seedtick (Apr 24, 2019)
  3. #32
    Sep 2015
    Ontario Calif USA
    After seeing it I can accept that the rotation lines up the holes.
    But i never would have thought of it.
    Jim
  4. The Following User Says Thank You to jimfols For This Useful Post:
  5. #33
    Supporting Member gatz's Avatar
    gatz's Tools
    uhmm, enlighten me as to how the holes get lined up....
  6. #34
    Quote Originally Posted by gatz View Post
    Pretty simple really there are microscopic gnomes running pell-mell along the rotating shafts aligning the beads up as the run by.
    No seriously it is a matter of the center of gravity by rolling the beads the absence of a center mass say from pole to pole means the greater mass is along the equator the gyroscopic effect will cause the bead's equator to seek perpendicular tp the axis.
    But I kike the gnomes better
  7. The Following 7 Users Say Thank You to Frank S For This Useful Post:
    baja (Apr 25, 2019), Gromet (Apr 25, 2019), IAMSatisfied (Apr 24, 2019), Moby Duck (Apr 24, 2019), ranald (May 6, 2019), Scotsman Hosie (Apr 24, 2019), Toolmaker51 (Apr 26, 2019)
  8. #35
    gatz's Tools
    OK, makes sense now.
    The gnomes theory actually sounds better.
  9. #36
    Jan 2016
    Moby Duck's Tools
    Great explanation Frank. Very clear now, but I had no idea before you explained it.
  10. The Following User Says Thank You to Moby Duck For This Useful Post:
  11. #37
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    Frank S seems to be one of those clear-eyed devils. Able to take in all the variables — at a glance — and immediately account for their overall effects. On the situation ... around the area. That — or he has massive amounts of experience, under his belt.
    Kudos, Frank.
  12. The Following 3 Users Say Thank You to Scotsman Hosie For This Useful Post:
    baja (Apr 25, 2019), Frank S (Apr 24, 2019), ranald (May 6, 2019)
  13. #38
    Quote Originally Posted by Scotsman Hosie View Post
    Kudos, Frank.
    I like the clear eyed devil analogy LOl.
  14. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    Scotsman Hosie (Apr 27, 2019), Toolmaker51 (Apr 26, 2019)
  15. #39
    Physicists describe it as polhode motion. This article...
    https://en.wikipedia.org/wiki/Polhode
    describes it in detail. This quote...
    any rotating body will continue to change its orientation until it has stabilized around its axis of maximum inertia, where the amount of energy corresponding to its angular momentum is least.
    from the end of the article sums it up nicely.
    Home Shop Freeware
  16. The Following 4 Users Say Thank You to mklotz For This Useful Post:
    Jon (Apr 25, 2019), olderdan (Apr 25, 2019), Scotsman Hosie (Apr 27, 2019), Toolmaker51 (Apr 26, 2019)
  17. #40
  18. The Following 6 Users Say Thank You to Jon For This Useful Post:
    high-side (May 4, 2019), jimfols (May 3, 2019), KustomsbyKent (May 8, 2019), Scotsman Hosie (May 3, 2019), Seedtick (May 3, 2019), Toolmaker51 (May 3, 2019)
