Portable Air Tank
I picked up this cheap pancake air compressor at Sears 5 or 6 years ago. The little compressor finally took a dump so I turned the tank into a portable one and saved the motor. The motor still works, just doesn't compress air anymore.
http://images16.fotki.com/v369/photo...MVC005F-vi.jpg
I made this adapter from two quick disconnect fittings so I can fill the tank right from my air hose.
http://images41.fotki.com/v1634/phot...MVC008F-vi.jpg
I just plug the fittings together and crack the ball valve on the hose until the little tank has about 90 PSI in it.
http://images45.fotki.com/v1636/phot...MVC006F-vi.jpg
Turn off the valve and unplug the fitting from the tank. It fills pretty quick. It's only 3 gallons...
Mark
Thanks astroracer! We've added your Portable Air Tank to our Air Compressors category,
as well as to your builder page: astroracer's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-portable-air-tank">
<img src="/uploads/156625/homemade-portable-air-tank.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-portable-air-tank">Portable Air Tank</a>
<span> by <a href="http://www.homemadetools.net/builder/astroracer_2">astroracer</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/gauge'>gauge</a>, <a href='http://www.homemadetools.net/tag/valve'>valve</a>, <a href='http://www.homemadetools.net/tag/tank'>tank</a> </div>
</div>
</div>
</div>
Damn! NICE Connection Idea, THX !
Thanks! I've already used this thing a couple of times. I am going to re-do the QD fitting. I am going to put a 90 degree elbow in place of the adapter fitting so I can put the original handle back on. Right no it will block access to the fitting when screwed back on.
