PVC Cutter with Built In Can Top Opener
If you use a PVC Cutter, I bet you also use PVC primer and solvent. How do you unscrew the can tops? I use a slip lock pliers but it is never nearby. Problem now solved by modifying the PVC Cutter so it can also open the tops.
http://rick.sparber.org/PCWSC.pdf
Please note: if this URL doesn't work for you, verify that all dots are in place. Some mail handlers eat one or two. It should include Rick DOT Sparber DOT org.
Thanks,
Rick
