QCTP height setup
Hi,
I frequently use my QCTP for holding my Dremel, for grinding or sanding on the lathe.
Then, I need to be able to setup the height along the vertical axis with a wider range than what simply permits the QCTP.
I have imagined this simple setup that allows for setting up the tool both lower and higher than what is possible with the original system.
I replaced the set screw by a long screw, and I inserted this angled piece of metal sheet under the handle.
The knurled knob stops against this inserted stop, and the vertical setting up range is widely enhanced.
Of course, when I come to be limited, I shift to my milling square, but this takes more time to install.
http://www.labellenote.fr/file/homem...ht_setting.JPG
Thanks Christophe! We've added your QCTP Height Setup Method to our Rotary Tools category, as well as to your builder page: Christophe's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/qctp-height-setup-method"><img src="https://www.homemadetools.net/uploads/236881/homemade-qctp-height-setup-method.jpeg"
/></a></div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/qctp-height-setup-method">QCTP Height Setup Method</a>
<span> by <a href="/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<div class="tags">tags: <a href="http://www.homemadetools.net/tag/sander">sander</a>, <a href="http://www.homemadetools.net/tag/grinding">grinding</a>, <a href="http://www.homemadetools.net/tag/rotary-tool">rotary tool</a>, <a href="http://www.homemadetools.net/tag/qctp">QCTP</a></div>
</div>
</div>
</div>
