Results 1 to 10 of 11
Thread: Quenching an anvil in a river, with an excavator - GIF
    Quenching an anvil in a river, with an excavator. The explanation is that this was necessary because the anvil was softened by a shop fire.
    Quenching an enormous gear - GIF
    Panzer tank hull being quenched
    Giant gearshaft being quenched - GIF
  2. The Following 6 Users Say Thank You to Jon For This Useful Post:
    carloski (Oct 5, 2021), KustomsbyKent (Nov 23, 2018), PJs (Nov 24, 2018), rlm98253 (Nov 22, 2018), Seedtick (Nov 22, 2018), will52100 (Nov 22, 2018)
    Supporting Member will52100's Avatar
    Oct 2015
    Bassfield, MS
    will52100's Tools
    Now that is an awesome way to make sure you've got enough water to cool the mass of steel.
    courtneyknives.net
    Took a big chance that the chain they welded to the bottom of the anvil would still have enough tensile strength in those red hot links to hold together once the anvil was heated
  5. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    PJs (Nov 24, 2018), will52100 (Nov 22, 2018)
    Oct 2015
    Bassfield, MS
    will52100's Tools
    That would have been my concern. Leads me to think they may not have been at critical temp. It's also possible that they added the chain once the anvil was up to temp. At 1500+ deg. F. steel is very very plastic. It's hard to tell from the vid, and colors never do come through right, but I suspect they were not quite to critical temp with the anvil. Also didn't see any air blower to feed the fire, but that might have been off to the side of the vid.
    I believe I'd have made a chain lasso and looped it around the waist right before pulling the anvil from the fire and quenching. In any event, using the river and an excavator to quench with is a very good idea.
    courtneyknives.net
    Sep 2018
    For what it’s worth and not wishing to upset anyone. - Anvils should have a case hardened surface only. The rest of the anvil is generally soft or mild steel. If you see an old anvil used by yesteryear Blacksmith invariably you would notice on its winged base chisel gouges. Often this is where the Blacksmith would test a hardened and tempered tool ( chisel ) to see if it cuts well without any noticeable dulling of the sharpened end.
  8. The Following User Says Thank You to Shopmate For This Useful Post:
    PJs (Nov 24, 2018)
    Quote Originally Posted by Shopmate View Post
    You're absolutely right and if that is an old iron anvil I bet I could knock the horn off it now with a 1 handed 4 lb hammer
  10. #7
    Sep 2018
    Not the one I did my 5year indentured apprenticeship as a Blacksmith at an OZ Naval Dockyard.
  11. #8
    Oct 2015
    Bassfield, MS
    will52100's Tools
    Old anvils were generally wrought iron, some welded up from two or three pieces, with a 1/2" or so thick high carbon steel face forge welded on. That's where the "step" comes from on London pattern anvils and the face is fully hardened.
    Others, like my Reffinghause anvil are hardened to a depth of about an inch. It's good to have a soft core, but that's more from the fact that it's nearly impossible to cool that large a chunk of steel fast enough than from design, it just works out that it's a good thing.
    courtneyknives.net
  12. #9
    Oct 2016
    old kodger's Tools
    Hell of a way to get a warm bath!
    Rob.
  13. #10
    Aug 2016
    wizard69's Tools
    I was always under the impression that good anvils where steel. How the steel hardens would be a big function of the alloy and quench medium.
