2 Attachment(s)
R8 pin locator
Do you fish around for the locator pin every time you insert an R8 into the spindle? Use your hand held electric drill to cut a small, shallow hole in the perimeter of the spindle right over the slot. It could be 0.1” in diameter and 0.05” deep. Fill it with red nail polish and then wipe level. Alternately, you can grind a shallow groove with a Dremel and fill with nail polish.
If you want to be extra fancy, grind tilted lines +/- 90° from the slot with the low end closest to the slot. They will tell you which way to turn the spindle to get to the locating pin.
Attachment 3918
Very useful post as usual, Rick, but am sorta surprised that there's not even an accompanying picture. Your posts are usually so detailed. :)
DIYer,
I heard you. See original post.
Thanks,
Rick
Thanks Rick! I've added your R8 Pin Locating Method to our Machining category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/r8-pin-locating-method"><img src="http://www.homemadetools.net/uploads/122014/r8-pin-locating-method.jpeg"
/></a></div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/r8-pin-locating-method">R8 Pin Locating Method</a>
<span> by <a href="/builder/Rick+Sparber_2">Rick Sparber</a></span>
</div>
<div class="tags">tags: <a href="http://www.homemadetools.net/tag/marking">marking</a>, <a href="http://www.homemadetools.net/tag/r8">R8</a>, <a href="http://www.homemadetools.net/tag/spindle">spindle</a></div>
</div>
</div>
</div>
