Ring Mandrel
Hi everybody !
This is simple tool, I managed to do without it in the past, but now I'm thinking I should have done it before (thought I had one made out of wood).
It is a ring mandrel, in order to turn both metal or wooden rings. It's basically used to finish the external profile, and apply the finish for wooden rings.
http://www.labellenote.fr/file/homem..._mandrel_1.jpg
It's made of aluminum, The dimensions are 25mm largest diameter, 14 mm smaller diameter, taper is 16cm long.
Here I show it mounted on the metal lathe, but I can use it as well on the wood lathe.
http://www.labellenote.fr/file/homem..._Mandrel_2.jpg
Cheers,
Christophe
Thanks Christophe Mineau! We've added your Ring Mandrel to our Workholding category,
as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-ring-mandrel-2">
<img src="/uploads/158225/homemade-ring-mandrel-2.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-ring-mandrel-2">Ring Mandrel</a>
<span> by <a href="http://www.homemadetools.net/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/mandrel'>mandrel</a> </div>
</div>
</div>
</div>
