2 Attachment(s)
Rod Storage Array Using PVC Pipe and PVC Glue
I needed a place to keep 12" long or so pieces of brass and some MT2 drill bits.
Pvc pipe seemed like a good idea but making a face with all the holes for the tubes
seemed like a lot of work. So, I simply used pvc cement and glued them into a group
putting a bead of glue on the point of contact of the tubes. Stronger than I could
imagine and fast to put together. Here is a picture of it all assembled and loaded.
Two different sizes of pipe were used for the various items to be stored.
They are separated by a piece of plywood.
The next picture is the vertical rack attached to the cabinet with "Goop". Really good stuff.
Cheers, JR
