Results 1 to 10 of 12
Thread: Sand mold casting explosion - GIF
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    carloski (Sep 13, 2022), rlm98253 (Oct 15, 2018), rossbotics (Oct 17, 2018), Seedtick (Oct 15, 2018), will52100 (Oct 15, 2018)
    BTS
    BTS is offline
    Jul 2018
    That gives me flash backs to a previous life. Had a few go up in the day.
    Green sand molding, a bit of a lost art these days in the commercial world.
    Sep 2012
    Hinchinbrook QLD
    Looks like they didnt have sufficient weights on that mold. You can see it float up just before the metal escapes.
  5. The Following 2 Users Say Thank You to 12bolts For This Useful Post:
    mwmkravchenko (Oct 22, 2018), PJs (Oct 15, 2018)
    Or perhaps the drag sand was too thin. It lifted the entire near left norner.
  7. The Following User Says Thank You to neilbourjaily For This Useful Post:
    PJs (Oct 15, 2018)
    Jan 2016
    Quote Originally Posted by 12bolts View Post
    Wet sand is the cause.
  9. The Following User Says Thank You to sven875 For This Useful Post:
  10. #6
    Feb 2018
    Wet sand can cause a steam explosion and that is what this looked like to me.
  11. The Following User Says Thank You to VinnieL For This Useful Post:
  12. #7
    I like all of the PPE worn in this casting explosion. Big boom, and lots of people real close by, but I doubt there were any serious burns.
  13. The Following 2 Users Say Thank You to Jon For This Useful Post:
    Seedtick (Dec 6, 2018), Sleykin (Dec 8, 2018)
  14. #8
    hemmjo's Tools
    The explosion appears to happen when the molten metal lands on the ground, vaporizing the moisture in the ground.
  15. The Following User Says Thank You to hemmjo For This Useful Post:
    PJs (Dec 7, 2018)
  16. #9
    Aug 2012
    Australia
    desbromilow's Tools
    thats a cast iron pour using a small cupola... the explosion seems to be when the molten iron hits the ground, so probably moisture in the ground.
  17. #10
    Aug 2016
    wizard69's Tools
    It looks like cast iron too. If so can’t imagine that there where no injuries. PPE or not that iron or steel can malt / burn through a lot of protective gear with ease.
    The interesting thing is that this appears to be out doors so you have to wonder if the guys doing the pour where aware of the risk of a steam explosion. Back in the day that was one of the few things stressed in the Zinc die cast foundry I worked in, steam becomes an extremely powerful explosive when confined in melted metal. Zinc die casting only happens around 850degrees too, imagine how hot that iron is.
  18. The Following User Says Thank You to wizard69 For This Useful Post:
    silverback prime (Nov 2, 2021)
