Sanding blocks
These are two sanding blocks I made just to try out some ideas for anchoring the sandpaper to the block. Both of them employ a wedge arrangement that secures both ends of the paper strip at once. A single screw secures the wedge to the block making paper changes quick and easy.
As a modest mathematics exercise both blocks are dimensioned such that a single strip cut from a standard sheet of sandpaper fits exactly without any trimming to length required.
Thanks mklotz! We've added your Sanding Blocks to our Sanding category, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/sanding-blocks-11"><img src="http://www.homemadetools.net/uploads/137526/sanding-blocks-11.jpeg"
/></a></div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/sanding-blocks-11">Sanding Blocks</a>
<span> by <a href="/builder/mklotz_3">mklotz</a></span>
</div>
<div class="tags">tags: <a href="http://www.homemadetools.net/tag/sanding-block">sanding block</a></div>
</div>
</div>
</div>
