Results 1 to 7 of 7
Thread: Sawing Small Pieces of Round Stock
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    When a piece of round stock is too short, it will not be able to bridge the gap in the vise of my horizontal/vertical bandsaw. A common technique is to put a bar under it. That works fine unless the bar is wider than the stock.
    A simple trick solves that problem.
    If you are interested, please see the video at
    Thanks,
    Rick
    Rick
  2. The Following 14 Users Say Thank You to rgsparber For This Useful Post:
    Andyt (Mar 22, 2019), baja (May 30, 2021), elk-a-holic (May 26, 2021), high-side (Mar 24, 2019), lassab999 (Oct 26, 2023), MeJasonT (May 8, 2019), Paul Jones (Mar 25, 2019), Rangi (Mar 22, 2019), Sam's Workshop Diary (Mar 27, 2019), Scotsman Hosie (May 8, 2019), Seedtick (Mar 21, 2019), Sleykin (May 26, 2021), Tonyg (Mar 22, 2019), tuchie (Oct 26, 2023)
    Thanks Rick Sparber! We've added your Small Bar Sawing Method to our Metalworking category,
    as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
    Apr 2012
    NorCal
    Saltfever's Tools
    It appears you have made a "quick-adjustible" threaded rod for your horizontal saw vise. Please give a few more details about it!
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    rgsparber,
    That is a great idea for a common isue!!!
    Dick
    Links to some of my plans:
  6. The Following User Says Thank You to old_toolmaker For This Useful Post:
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    It appears you have made a "quick-adjustable" threaded rod for your horizontal saw vise. Please give a few more details about it!
    The threaded rod has flats on two sides axially. The hole in the jaw matches it. When one of the flats faces up, the rod freely slides in and out. When rotated less than 180 degrees, it is advanced with the threads.
    Rick
    Rick
  8. The Following 3 Users Say Thank You to rgsparber For This Useful Post:
    elk-a-holic (May 26, 2021), Saltfever (Mar 24, 2019), Scotsman Hosie (May 8, 2019)
    Dec 2017
    Cape Coral, FL
    rgsparber,
    That is a good idea for a quick-set threaded stop.
    Dick
  10. #7
    Apr 2014
    Gadgeteer's Tools
    Rick,
    That was a rather bland explanation on how to cut short pieces. How about more drama next time? Thanks for the tip.
