4 Attachment(s)
Scissor Lift Extentions
Made these for my mid-rise 6000 lb.scissor lift to give me more room to work on exhaust systems or for lifting a pick-up truck for repairs. I used 3x3x.125 box and 1/4" for all else. The height can now add and additional 9" the the lifts capacity. I added round rubber pads that I bought on e-bay for post type lifts to round 1/4" by 6" discs to add stability. I used 2x2x 1/4" angle and cut and machined it to size to make the base slides. The short one is what the lift comes with. I know these are available from the manufacturer but I had everything on hand to make them and saved myself a couple of hundred bucks. Using these on a car requires a little more set up time, but its worth it. Thanks for looking.
Thanks charles scozzari! We've added your Scissor Lift Extensions to our Jacks and Lifts category,
as well as to your builder page: charles scozzari's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-scissor-lift-extensions">
<img src="/uploads/208576/homemade-scissor-lift-extensions.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-scissor-lift-extensions">Scissor Lift Extensions</a>
<span> by <a href="http://www.homemadetools.net/builder/charles+scozzari">charles scozzari</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/lifting'>lifting</a> </div>
</div>
</div>
</div>
