Results 1 to 10 of 18
Thread: Sensitive Drill Press
    Dec 2013
    Florida
    rossbotics's Tools
    I designed and built this little drill press for drilling and reaming small holes that I occasionally encounter, It want get used on a continuous basis but it will come in handy when the time arrives, I want to start making small engines in the very near future so this machine will earn its place in the shop.
    The drill press is powered by a sewing machine motor (that might get changed out later) with a potentiometer type speed controller; the motor has a Max. RPM of 7,000 which I reduced to 2,300 by means of two machined pulleys, the motor has a 1” diameter pulley and the machines spindle has a 3”, power is transmitted from the motor to the spindle by a 3/16” diameter black urethane belt, unlike normal drill presses where the spindle travels up and down, on this drill press the table travels up and down by means of a rack and pinion gear with a small handle, with a small handle or round hand wheel you can actually feel the drill bit cutting thus reducing drill breakage.
    The spindle of the machine rotates in two ball bearings, the upper spindle bearing is a sealed single row 6202 and the lower bearing is a sealed 5202 double row angular contact, it has a 0-1/4” drill chuck but it might get converted over to a rubber collet type system eventually, we’ll see!
    The base of the machine was fabricated from a piece of 3/4" A-36 steel plate, there are four 1” diameter delrin feet on the bottom of the base for easy moving around on a table, the column, yoke clamp, spindle, rack and pinion shaft were made from 303 TG&P stainless steel shafting, the head, yoke and flanges were made from 6061 aluminum and a touch of C-360 brass on the yoke clamp and hand lever, this machine works and functions as intended.
    Below you will find some photos of the machining process along with a video of the machine being used.
    As always thanks for looking
    And happy machining
    Doug
    Comments are always welcome
    Doug
  2. The Following 17 Users Say Thank You to rossbotics For This Useful Post:
    aphilipmarcou (Nov 23, 2017), Captainleeward (Nov 23, 2017), Christophe Mineau (Nov 23, 2017), Dimitris Polychronis (Nov 14, 2018), HobieDave (Mar 27, 2020), Jon (Nov 23, 2017), LMMasterMariner (Nov 23, 2017), Metallurg33 (Apr 25, 2018), Miloslav (Dec 21, 2018), mklotz (Nov 23, 2017), olderdan (Nov 24, 2017), Paul Jones (Nov 25, 2017), Seedtick (Nov 23, 2017), thevillageinn (Nov 25, 2017), Toolmaker51 (Jan 9, 2020), Tuomas (Nov 24, 2017), uv8452 (Feb 18, 2024)
    Beautiful work, Doug. I love it.
    I'll offer a suggestion you might want to consider...
    Think about supplying the table elevator lever with an adjustable counterweight arrangement. My experience with my own miniature drilling table lift indicates that a counterweight provides an even more sensitive feel.
    Home Shop Freeware
  4. The Following 4 Users Say Thank You to mklotz For This Useful Post:
    Paul Jones (Nov 25, 2017), rossbotics (Nov 24, 2017), tonyfoale (Jan 10, 2020), Toolmaker51 (Jan 9, 2020)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Same for me, really nice Doug, I love this idea of lifting the table !
    Cheers !
    Christophe
    Facebook : La Belle Note
  6. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    rossbotics (Nov 26, 2017)
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    O thats a KEEPER..............OH YAH....:O)
  8. The Following User Says Thank You to Captainleeward For This Useful Post:
    Dec 2013
    Florida
    rossbotics's Tools
    Great idea Marv, thanks for the comment
    Doug
  10. #6
    Nice project, I have a Dremel drill press that gives lots of speed, but its not very stable or smooth.
  11. The Following User Says Thank You to Metallurg33 For This Useful Post:
  12. #7
    Supporting Member aphilipmarcou's Avatar
    Dec 2016
    new zealand
    aphilipmarcou's Tools
    Mouth watering project..... Guarranteed perpendicular holes at all times.....
  13. The Following User Says Thank You to aphilipmarcou For This Useful Post:
  14. #8
    Jyväskylä Finland
    Tuomas's Tools
    Really great work!
    It also looks beautifull.
  15. #9
    Quote Originally Posted by Metallurg33 View Post
    You might consider making one of these...
    http://www.homemadetools.net/forum/s...0287#post91042
    Home Shop Freeware
  16. The Following User Says Thank You to mklotz For This Useful Post:
  17. #10
    That's a nice table. I can see how it would give the stability and smooth movement you need for small drills.
