Simple beam compass
HI,
Here is my super simple beam compass, allows to draw large circles, with a centimeter basis radius.
Basically, you need one hole every 5 or 10 cm, plus, between hole 0 and 5 or 10, one hole every cm.
Putting your pencil on one hole, and a pin at the other end, you can draw any circle with radius stepping from cm to cm.
Here below, a circle with radius = 20 - 3 = 17 cm
http://www.labellenote.fr/file/homem.../Compas_01.jpg
http://www.labellenote.fr/file/homem.../Compas_02.jpg
Simplicity at its best. Much better than the string method in terms of accuracy.
Al
Christophe,
Judging from your beautiful woodwork, I know this tool must work well for you.
Thanks for sharing, Paul
Great ideia Chistophe...
:hattip:
Thanks friends,
Paul, talking about this particular tool, this is far from a piece of art, it's just a quick idea done with a piece of scrap, one day I had a special emergency need, and finally, the scrap lasted and has served several times since ...
When I will have time, I will probably make one like John Heisz'.
Cheers
Christophe
Thanks Christophe! I've added your Beam Compass to our Rulers' Protractors, and Compasses category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/beam-compass-6"><img src="http://www.homemadetools.net/uploads/121702/beam-compass-6.jpeg"
/></a></div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/beam-compass-6">Beam Compass</a>
<span> by <a href="/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<div class="tags">tags: <a href="http://www.homemadetools.net/tag/compass">compass</a></div>
</div>
</div>
</div>
Sometimes, simple is the best. A no fuss tool!
