Results 1 to 10 of 10
Thread: Simple dowel maker jig made with construction washers
    Supporting Member dekeros's Avatar
    Oct 2018
    Sweden
    dekeros's Tools
    Using ordinary and cheap construction washers for the cutting parts - makes this simple and cheap. If the edges get dull I can change just that specific one, instead of throwing the entire jig away.
    I make things, jigs and tools on my small YouTube channel. Mostly woodworking and DIY related.
    Check it out here : https://www.youtube.com/channel/UCiz...EOqWDZu501V0Ug
    Or you can find me on other places here : https://linktr.ee/dekeros
  2. The Following 21 Users Say Thank You to dekeros For This Useful Post:
    Andyt (Nov 20, 2018), baja (Nov 20, 2018), Ed Weldon (Nov 25, 2018), high-side (Feb 20, 2019), homey_g (Jun 15, 2021), Jon (Nov 19, 2018), Komo (Nov 21, 2018), LMMasterMariner (Nov 19, 2018), PJs (Nov 20, 2018), ranald (Nov 19, 2018), rlm98253 (Nov 19, 2018), rossbotics (Nov 18, 2018), saintrain (Nov 18, 2018), Seedtick (Nov 19, 2018), Shanty (Nov 19, 2018), sossol (Nov 20, 2018), Texf1 (Nov 26, 2018), threesixesinarow (Nov 19, 2018), tuchie (Nov 8, 2023), Tuomas (Apr 17, 2019), volodar (Nov 20, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Very Good dekeros, great work !
    Doug
    Comments are always welcome
    Doug
  4. The Following User Says Thank You to rossbotics For This Useful Post:
    dekeros (Nov 18, 2018)
    Oct 2018
    Sweden
    dekeros's Tools
    Thank you very much! :-)
    Mar 2018
    Fantastic! Never seen this. Great tool.
  7. The Following User Says Thank You to Tkesler For This Useful Post:
    dekeros (Nov 19, 2018)
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Nice and simple. Thanks for sharing.
  9. The Following User Says Thank You to LMMasterMariner For This Useful Post:
  10. #6
    Oct 2018
    Sweden
    dekeros's Tools
    Thank you very much! This is an adaption of the more common (as far as my knowledge takes me) using holes in angle/L-iron.
  11. #7
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    Works well. I have used some thick steel plate for years butyours is better for non metal workers. I only have 3 sizes so I may consider doing other sizes with your idea. They need to be precise for great fitting hardwood wooden threads.
    cheers
  12. The Following User Says Thank You to ranald For This Useful Post:
    dekeros (Nov 20, 2018)
  13. #8
    Oct 2018
    Sweden
    dekeros's Tools
    Thank you very much! For more precision I would suggest using a drill press or pillar drill, not like me - with a hand held drill. :-) Thanks again!
  14. The Following User Says Thank You to dekeros For This Useful Post:
    PJs (Nov 20, 2018)
  15. #9
    Thanks dekeros! We've added your Dowel Jig to our Jigs category,
    as well as to your builder page: dekeros's Homemade Tools. Your receipt:
  16. The Following User Says Thank You to DIYer For This Useful Post:
    dekeros (Nov 21, 2018)
  17. #10
    Congratulations dekeros - your Dowel Jig has been retroactively awarded Homemade Tool of the Week!
    Three of our 237 Homemade Tool of the Week awards were removed from a builder who copied others' tool build videos and claimed them as his own. Therefore, you are (and always were) the rightful winner of this award!
    Some more nice builds from that week:
    Electric Wire Brush by liberal
    Offset Square by rossbotics
    Indicator Swivel Rod Connectors by jjr2001
    Workbench by LastingBuild
    Splinter Tweezer Magnifier by mklotz
    Cast Shoulder Plane by Eaglewood
    Aluminum 2x72 Belt Grinder by mr95gst
    Splinter Syringe Removal Method by tonyfoale
    Air Hammer by Al8236
    Lathe Drum Sanding Attachment by darkoford
    Radius Cutting Tool by Kovanca Polock
    No-Spill Oil Can Mathematics by mklotz
    Drill Press by Lahis
    Unimat Compound by Stevohdee
    Mini Lathe by Lahis
    Ball Forging Tool by Kovanca Polock
    Grinder Sander by Lahis
    Lathe Belt Drive Modification by jjr2001
    Variable Power Supply by Lahis
    Moxon Vise by stuffucanmake
    Water Pump by Lahis
    dekeros - we've inserted your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
    You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
    Nice work!
