Results 1 to 10 of 14
Thread: Simple Machine for Processing Semiaxis
    Supporting Member liberal's Avatar
    Nov 2018
    liberal's Tools
    Thumbs up Simple Machine for Processing Semiaxis
    In this video, I build a machine for processing semiaxis. The machine will be wooden. For manufacturing I am using the old window jamb.
  2. The Following 9 Users Say Thank You to liberal For This Useful Post:
    Andyt (Jun 17, 2021), jimfols (Dec 11, 2018), Jon (Dec 9, 2018), Paul Jones (Dec 9, 2018), PJs (Dec 11, 2018), rlm98253 (Dec 10, 2018), Seedtick (Dec 10, 2018), Sleykin (Dec 17, 2018), Tonyg (Mar 15, 2019)
    Thanks liberal! We've added your Axle Grinding Tool to our Axle category,
    as well as to your builder page: liberal's Homemade Tools. Your receipt:
    liberal (Dec 17, 2018)
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    What exactly does this machine do?
    Nov 2018
    liberal's Tools
    This is for shortening a semiaxis.
    Jun 2018
    Massachusetts
    Radioman's Tools
    Quote Originally Posted by liberal View Post
    OK I can see how you could cut the axle down with this machine. What I’m interested in is what happens after you make the cut? Do you re-spline the cut end or do you also cut off the hub and welded back on? I’m having a hard time picturing in my mind how your axle would remain an axle after being cut on your machine? If you’re just looking to cut the axle down to use the steel for other fabrication I understand.
    Nov 2018
    liberal's Tools
    After processing, I just cut the splines with an angle grinder.
  9. The Following 3 Users Say Thank You to liberal For This Useful Post:
    Andyt (Jun 17, 2021), Jon (Dec 17, 2018), Toolmaker51 (Mar 17, 2019)
  10. #7
    that is some really good control to cut the splines freehand with an angle grinder.
  11. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    Andyt (Jun 17, 2021), bigtrev8xl (Jun 18, 2021), Gromet (Apr 28, 2019)
  12. #8
    Jun 2018
    Massachusetts
    Radioman's Tools
    Freehand cut splines using an angle grinder? Now I’ve seen everything. The amount of time I spent setting up my Bridgeport with an indexing head to cut my first set of splines was quite long. Just sourcing the correct endmill was a chore. If someone told me they could the job freehand with an angle grinder I would have had some choice words for them. I’m having trouble believing my own eyes. Nice work my fellow craftsman.
  13. The Following User Says Thank You to Radioman For This Useful Post:
  14. #9
    I would have used a special ground profile cutter and a rotary index I just don't have the hand control any more
  15. #10
    Supporting Member stillldoinit's Avatar
    May 2013
    stillldoinit's Tools
    You don't need no stinking milling machine. Beautiful work with the grinder.
  16. The Following User Says Thank You to stillldoinit For This Useful Post:
    liberal (Dec 25, 2018)
