Results 1 to 10 of 12
Thread: Simple Shim jig for Bandsaw
    Mar 2018
    Rorschach's Tools
    Doing a cabinet install next week and wanted some shims. Wooden shims are not commercially available here, only plastic and usually not tapered so I cut my own. When at home I just cut them to suit the job but since I will be off site I wanted to make a stack of them.
    Simply made from a runner of hardwood to fit the mitre slot and the top piece is a scrap of laminate flooring. Tacked in place with CA glue and then a few screws added. The edge is trued using the bandsaw and then I marked out a 5deg wedge for the shims. I make my shims from offcuts and the jig works great, made 2 dozen shims in a couple of minutes. Jig itself took less than 10minutes to make.
  2. The Following 2 Users Say Thank You to Rorschach For This Useful Post:
    Ken Koch (Aug 21, 2018), Seedtick (Aug 20, 2018)
    Quote Originally Posted by Rorschach View Post
    Magic - just what I need and have been trying to design for weeks
    Mi
    Thanks Rorschach! We've added your Bandsaw Shimming Jig to our Bandsaws category,
    as well as to your builder page: Rorschach's Homemade Tools. Your receipt:
    Mar 2018
    Rorschach's Tools
    Shimming jig isn't quite accurate, could cause some confusion maybe?
    Sure, that's reasonable. What title did you have in mind?
    Mar 2018
    Rorschach's Tools
    How about "Simple shim/wedge cutting jig for the Bandsaw or Table saw" Bit long winded maybe?
    Just don't want someone to see it and think it's for adjusting the bandsaw angle or something.
  8. #7
    This is one of those examples where several possibilities for a description are correct yet none can completely describe with fewer words.
    Wedge cutting jig, shim cutting jig, tapered shim cutting jig,
    The problem is some folks will call them by several names.
    Often when I need a wedge for a hammer handle I will use 2" long end cut off of a hardwood board set the vice in my horizontal band was to a slight angle then after the first cut merely turn the board over and cut another. Longer end cut pieces make longer wedges.
    A 1 by 12 or 2 by 12 will yield several wedges before the piece of wood becomes too short to safely hold
    Rorschach's simple jig does the same thing only his jig insures all shims/ wedges are uniform providing he has a fence set up so his jig becomes what some have called a boat.
    I have found that if I cut a mesquite log into board shaped chunks they make excellent handle wedges
  9. #8
    Accurate, but needs to be shorter for a title.
  10. #9
    Mar 2018
    Rorschach's Tools
    "Shim/Wedge cutting Jig" Is that short enough?
  11. #10
    Mar 2018
    Rorschach's Tools
    No need for a fence with this jig.
