Remove advertisements
Results 1 to 10 of 11
Thread: Small angle drill press
    threesixesinarow's Avatar
    Mar 2018
    threesixesinarow's Tools
    I made a radial adapter that mounts my dovetailed Unimat headstock to a tilting column on a portable wooden base.
    The free end of the ball clamps around a cut off piece of bed rod for my watchmaker lathe, and Iíve been drilling with that but the new adapter is more adjustable and saves having to take the lathe apart.
    Next to my bigger, still small angle drill press
    Tilting forward and left, in the regular higher position
    Tilting back and right, in the upside down lower position
    Parts
  2. The Following 11 Users Say Thank You to threesixesinarow For This Useful Post:
    Frank S (01-04-2019), Jon (09-20-2018), MountainMan (09-21-2018), old_toolmaker (09-23-2018), Paul Jones (09-26-2018), philipUsesWood&Brass (09-20-2018), PJs (09-24-2018), rlm98253 (09-20-2018), rossbotics (09-20-2018), Seedtick (09-20-2018), Toolmaker51 (09-20-2018)
    Content Editor DIYer's Avatar
    Thanks threesixesinarow! We've added your Small Angle Drill Press to our Drilling and Drill Presses category,
    old_toolmaker's Avatar
    Dec 2017
    Minnesota
    old_toolmaker's Tools
    threesixesinarow,
    A great little multi directional portable drill!! I admire your ingenuity and originality!!
    Dick
    Links to some of my plans:
    http://www.homemadetools.net/forum/f...6068#post65876 OFF-SET TAILSTOCK CENTER PLANS
    Mar 2018
    Thanks, Dick,
    It beats drilling lots of angled holes by hand! I never tried Archimedes or bow drills, though.
    An easy improvement to it was right in front of me for days before I recognized it.
    Dec 2017
    Minnesota
    Is that a flat iron in the picture?
    Dick
    Mar 2018
    Quote Originally Posted by old_toolmaker View Post
    Yes, for ballast.
    A couple indicator bases might help to anchor the base when it’s on iron surfaces.
  8. #7
    Aug 2016
    wizard69's Tools
    That is one nice solution you have there. It leaves me with all sorts of ideas for a micro drill press. This is perhaps the greatest compliment One can offer up for a design, it gets the creative juices flowing in others. It starts with “why didn’t I think of that” and builds from there.
    I must ask, how much of a pain is it to get the angles right with that ball joint? Or for that matter get everything back to vertical square.
  9. #8
    Mar 2018
    Thanks, wizard69!
    I think its lack of nice adjustment is a big reason why the ball joint wasnít an obvious solution to me, but I use this for drilling lots of small close holes in big pieces of wood where consistency is more important than specific angles, so itís okay.
    Springy split lock washers on the clamping bolts help keep it from slipping while I adjust it.
    When I need a more normal micro drill press I just move the quill, or the whole headstock, to a different machine.
  10. #9
    Mr.Pete's Avatar
    Nov 2015
    Lightbulb Great tool , thanks
    Quote Originally Posted by threesixesinarow View Post
    Parts
    Thats a great idea... I could use one like this ! Whats the moter on your Unimat head?
  11. #10
    Mr.Pete's Avatar
    Nov 2015
    Thanks for the great idea... I could use one like this ! Whats the motor on your Unimat head.
