Results 1 to 10 of 20
Thread: Socket Wrench Thumb Wheel for close quarters use and speed use
    jjr2001's Tools
    It is much faster to spin on nuts with a little knob than using most any wrench.
    Using just a socket will usually result in sticking due to coarse threads or even small amounts of junk in the threads or small burrs.
    This little tool will allow you to spin on nuts fast.
    It also will do most of the turning in close access areas where the ratchet is moved rapidly in short strokes.
    Easy to make and use.
    I made mine with a new rotary broaching tool that I just finished but you could use other methods such as
    using allthread for the knurled knob attachment and then just tapping out the knurled knob to the thread size on the allthread.
    The thread of the allthread would be removed for the part that will engage the socket.
    For mine I used some key stock for the 1/4 inch one and then just milled down some 3/8 cold rolled to fit in the 1/4" broached hole in the knob.
    Cheers JR
    Attached Thumbnails Attached Thumbnails Socket Wrench Thumb Wheel for close quarters use and speed use-img_2365.jpg   Socket Wrench Thumb Wheel for close quarters use and speed use-img_2364.jpg   Socket Wrench Thumb Wheel for close quarters use and speed use-img_2366.jpg
  2. The Following 11 Users Say Thank You to jjr2001 For This Useful Post:
    Andyt (Feb 8, 2019), baja (Feb 7, 2019), Jon (Feb 6, 2019), Paul Jones (Feb 10, 2019), PJs (Feb 8, 2019), rlm98253 (Feb 7, 2019), rossbotics (Feb 8, 2019), Scotty1 (Feb 7, 2019), sossol (Feb 8, 2019), Toolmaker51 (Feb 9, 2019), Tule (Feb 8, 2019)
    I have a few bought ones like these but they have a racket built-in. Very useful devices.
  4. The Following User Says Thank You to tonyfoale For This Useful Post:
    jjr2001 (Feb 8, 2019)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    JR that was a great idea! I love/loved those things for years...ok, at least 3+ decades. Have whats left of several sets (1/4, 3/8, 1/2) that I got from Matco, IIRC back in the day. Mine were metal set into a phenolic or plastic of some kind perfect fitting knob and had ball detents to hold the sockets or extensions. Used them so much I wore out the ball detent then made a special drift punch to re-crimp the ball and spring.
    I've tried the knurled ones and found them to be too small and not as comfortable. I like the scallop shape to these and the thickness of the knob gives a good feel. If I had a mill I might try this shape.
    Here are a couple of 3/8" I have.
    Socket Wrench Thumb Wheel for close quarters use and speed use-ratchet_knobs_800x600.jpg
    Thanks for the great idea and post!
    PJ
    Mark Twain
  6. The Following 3 Users Say Thank You to PJs For This Useful Post:
    jjr2001 (Feb 8, 2019), Paul Jones (Feb 10, 2019), sossol (Feb 8, 2019)
    jjr2001's Tools
    Thanks PJ, I like that Craftsman ratchet. I have one without the universal and frequently found the
    little knurled wheel handy when in tight spaces.
    Thanks for posting.
    Cheers, JR
  8. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    Paul Jones (Feb 10, 2019), PJs (Feb 9, 2019)
    jjr2001's Tools
    Thanks Tony, I don't think I have ever seen one with a ratchet. That would be a very useful tool.
    Cheers, JR
  10. #6
    Cheers, JR
    I'll take some pix in the morning, well later this morning it is 01:10 as I write this.
  11. The Following User Says Thank You to tonyfoale For This Useful Post:
  12. #7
    Cheers, JR
    Here is a pic of my collection, rather than write a story I made a short video with details of each one.
    Socket Wrench Thumb Wheel for close quarters use and speed use-thecollection.jpg Click for full size.
    The video is here on YouTube
  13. The Following 8 Users Say Thank You to tonyfoale For This Useful Post:
    Alan Purdy (Feb 10, 2019), Altair (Jan 20, 2021), DIYer (Feb 14, 2019), jjr2001 (Feb 9, 2019), Jon (Feb 9, 2019), olderdan (Feb 9, 2019), Paul Jones (Feb 10, 2019), Toolmaker51 (Feb 9, 2019)
  14. #8
    jjr2001's Tools
    Thank you Tony, very informative video you posted there. I had no idea that so many different types of "thumb wrenches" were produced.
    Cheers, JR
  15. The Following User Says Thank You to jjr2001 For This Useful Post:
    tonyfoale (Feb 9, 2019)
  16. #9
    A few picks from a patent search using query TTL/finger$ AND CCL/81/$ AND APT/1, performed at USPTO Advanced Patent Search.
    Extendible Finger Wrench
    Finger Wrench
    Finger Wrench or the Like
  17. The Following 4 Users Say Thank You to Jon For This Useful Post:
    baja (Feb 10, 2019), jjr2001 (Feb 16, 2019), PJs (Feb 9, 2019), tonyfoale (Feb 9, 2019)
  18. #10
    Socket Wrench Thumbwheel...It is much faster to spin on nuts with a little knob than using most any wrench.
    Cheers JR
    Like Tony Foale, I'm a happy user of ratchet spinners. jjr2001's rigid variety are better than a close second. I'd like to twiddle metering valves, idle speed adjustments etc., with something that could stay in place, compared to a screwdriver. Fine tuning, while switching a ratchet throws the setting and just doesn't work.
    I'd make one addition. The knurled portion is good when needing torque; add a small diameter stem long enough thumb/forefinger could impart a little faster RPM on easy threads.
  19. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    DIYer (Feb 14, 2019), jjr2001 (Feb 10, 2019)
