Yep, just because you used a tenths DTI doesn't mean you can brag that you checked your square's orthogonality to tenths accuracy.
I wanted novices to be made aware that verifying the orthogonality of the outside angle of the square doesn't automatically proof the inner angle.
Designing test procedures like this requires the ability to visualize all sorts of possible error mechanisms. It's good training for designing machining setups.
Great looking shop!
Your work is fine art to me!
Very nice work. Keep up the
good work!
I would consider myself gifted
if I could use my machines 1/10
as well as you folks do.
Did you consider grinding a flat on the back of the column so that the gauge can be re-positioned with same center relationship ?
Tooly.
