Surface Gauge base modified for measuring pieces for squareness. Ground slot and press fitted and a piece of 0.062 thick tool steel. Ground/Sanded a smooth radius. Works great.
Attachment 1049Attachment 1050
Thanks Catfish! I've added your Surface Gauge Base Modification to our Machining and Measuring and Marking categories, as well as to your builder page: Catfish's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="/surface-gauge-base-modification"><img src="/uploads/70692/surface-gauge-base-modification.jpeg" alt="Surface Gauge Base Modification" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="/surface-gauge-base-modification">Surface Gauge Base Modification</a> <span> by <a href="/builder/Catfish">Catfish</a></span> </div> <div class="tags"> tags: <a href="/tag/gauge">gauge</a>, <a href="/tag/square">square</a>, <a href="/tag/modification">modification</a> </div> </div> </div> </div>
