Results 1 to 10 of 11
Thread: Thin wall sockets ?
    Jun 2017
    Thin wall sockets ?
    Hi, I have been looking all over the net for a thin wall socket
    I need a 3/8 socket with an max OD of 13.3mm so it could fit in the 13.4mm hole.
    Any help would be greatly appreciated!
  2. The Following User Says Thank You to wave For This Useful Post:
    Seedtick (Jun 6, 2017)
    Quote Originally Posted by wave View Post
    Two thoughts...
    Buy a cheap socket and...
    turn it down on the lathe if you have one
    or
    grind it freehand with bench or angle grinder.
    Home Shop Freeware
  4. The Following User Says Thank You to mklotz For This Useful Post:
    Trojan Horse (Jun 6, 2017)
    Jun 2017
    Thanks but I need a bunch of them I am looking for something off the shelf.
    Maybe something like what you get with your car to remove the wheel? Its like a bent pipe...
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    Wave,
    Can you define what a bunch is? 10, 100, 1000?
    The problem is that socket manufacturers and resellers don't list the outside diameter of the socket, so it's anybody's guess one what the actual outside is until you measure it.
    The sheet metal style ones you're thinking of are typically for very large nuts, commonly for water heater element removal. Just google water heater element socket.
    How much torque are you applying to the fastener?
    Do you have any opportunity to change to an Allen socket head fastener? That would easily fit down in that hole, and Allen driver tools are readily available. Here's an example of that type of fastener:
    https://www.mscdirect.com/product/details/05520077
    Depending on your quantity needed, if it was less than 100, I'd take Marv's suggestion, and turn an existing socket down on the lathe. A machine shop could knock those out in short order. If you needed less than 10, and don't have a lathe, then the angle grinder method would work just fine.
    hemmjo's Tools
    Maybe I don't understand what you are looking for, but my Craftsman, short, 1/4 drive, 3/8 six point, number 43497 measures 13.2mm outside.
    Page 3 of this catalog http://www.btindustrial.com/downloads/section_3.pdf
    I have no affiliation with them, I just found it online.
    It is possible the newer ones are different. Mine about 50 years old. I have had this set since I was about 18. (I am pretty sure it has paid for itself)
    Sep 2012
    Hinchinbrook QLD
    What you are looking for is a tube spanner. Most stores that sell hand tools should carry them
  9. #7
    Apr 2016
    3/8 socket wth 13.4mm od.
    If drive size is not a problem a lot of 1/4 drive deep well sockets come very close. again turning may be necessary, around 13.89mm for craftsman
    Good luck ( can the hole be made larger ??????)
  10. #8
    May 2013
    just so i understand,, do you need a bunch of sockets, as in you are tooling up a bunch of workers, or you have a bunch of bolt/screws to take out,, more info would help,, how deep is the hole,, how deep does the socket need to be??? remember more info is more likely to be rewarded with more workable solutions,, buck
  11. #9
    May 2013
    ive had 2 arrests/strokes but im still pretty good at finding stuff and the closest i could get was the craftsman 1/4 drive 3/8 with an OD of 13.3 MM tjhere may be others but that was the only one i could find, armstrong had one at 13.98 mm,, buck
  12. #10
    Or, grind down (by hand) a "quality" impact socket (usually black in color) until it fits. Keep it cool with water while using your bare hands as a heat gauge. Very strong and you will still be able to use it for other applications. Deep well or shorty, I do not think lack of strength will be a factor.
    It seems funny to me that you mix american standard and metric.
    Vic
