Results 1 to 10 of 17
Thread: Tilting Dividing Fixture
    Dec 2013
    Florida
    rossbotics's Tools
    This tool was designed and made by me to facilitate in the holding of small to medium size parts to be machined or ground which require angular and simple indexing or both, such as multi flute milling cutters, square and hex punches just to name a few.
    Most of the posts that I have submitted are dealing with holding fixtures of some sort, it seems as though we’re always looking for a different or easier way to hold something that’s to be machined at angles, needing divisions or both, something small enough to setup in just a couple of minutes, something versatile, something ridged and accurate, something that makes time consuming setups quick and easy.
    The unit utilizes 5C collets with a 24 hole division ring incorporated on the spindle which gives the divisions of 2-3-4-6-8-12-24, the unit will tilt from vertical to the left 100°or to the right 100°, it has a spring loaded indexing plunger in the housing and a spindle lock screw with a brass seat, the base of the unit has a .625” slot milled on the bottom to accompany a key for locating itself onto the milling machine table, this key can be removed and the unit will sit on the magnetic chuck of a surface grinder or in a milling machine vise, if additional left and right angles are needed that are not achievable from the unit it can be held in the milling machine vise with a swivel base, or can be installed on the magnetic chuck of a surface grinder with the appropriate angle plate between the edge of the base and the back rail on the magnetic chuck.
    The entire tool was constructed from 4140 steel, although most any steel would be fine, 4140 is just my choice of steel, I make all my tooling and fixtures from this steel and hardened when necessary or purchase PreHardened.
    All surfaces were ground flat, parallel and square with each other, the Base, Column and Housing were assembled with socket head cap screws and carefully aligned,
    The graduated dial was engraved and stamped using a Machine Tool Dial Making Fixture which I designed and built, this fixture is posted in homemadetools.net as well.
    In the photos below you will see all the parts ready to be assembled and some of the machining steps, also there a couple photos of a simple square tapered punch being machined and ground using this tool.
    As always thanks for looking
    And happy machining
    Doug
    Completed Parts
    Assembled
    Drilling and Reaming the 24 holes
    Scribing a line horizontally to coincide with the graduations to be stamped
    All parts and drawings
    Side View
    Aligning the spindle horizontally
    Machining a 4 sided tapered punch
    For Demonstration Purposes
    Grinding the 4 sided tapered punch
    A finished ground punch
    Comments are always welcome
    Doug
  2. The Following 19 Users Say Thank You to rossbotics For This Useful Post:
    aphilipmarcou (May 14, 2018), bobs409 (May 1, 2017), Canobi (May 14, 2018), Canyonman44 (Jul 8, 2020), evilwrench (May 14, 2018), freddo4 (Jul 8, 2020), jjr2001 (May 1, 2017), LMMasterMariner (Apr 30, 2017), Metallurg33 (Sep 28, 2018), mklotz (Apr 30, 2017), Mr.Pete (May 1, 2017), NortonDommi (May 1, 2017), olderdan (May 2, 2017), Paul Jones (May 9, 2017), philipUsesWood&Brass (Jun 1, 2018), Seedtick (May 1, 2017), tooly (Jul 9, 2020), whitebear (Oct 29, 2023), zarembak (May 14, 2018)
    Dec 2016
    bobs409's Tools
    Wow, that's beautiful! Well done and a really good idea!
    whardin's Avatar
    Aug 2016
    This is a really nice tool. I'd like to make one,how can I get a copy of the drawings or cad model?
    hook86's Avatar
    Great job would love a copy of your plans to make one.
    Dec 2013
    Florida
    rossbotics's Tools
    Thank you very much for your compliment, there will be a complete set of cad drawings with multiple photos free to download soon, post your project when your finished, would enjoy seeing your craftsmanship
    Thank You
    Doug
    Doug
    Mr.Pete's Avatar
    Nov 2015
    Super nice job !
    I would love to make one myself ... with some small modifications I think I could adapt it for my Unimat sl.
  8. #7
    hook86's Avatar
    Looking forward to the download.
  9. #8
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    You are a master of the ' a picture tells a thousand words'.
  10. #9
    Dec 2013
    Florida
    rossbotics's Tools
    Thank You for your compliment,
    A complete set of detailed cad drawings and photos will be available for downloading soon
    Doug
  11. #10
    Thanks rossbotics! We've added your Tilting Dividing Fixture to our Machining category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
