A good work, based on the idea used on Schaublin and others small lathes makers, but a lot less expensive.:thumbsup:
I have exactly the same construction for a Schaublin 70 with the improvement of the independent motor you've made.
One is glad to be of service, Doug. What I was initially impressed with was the 17.5 thou of radial clearance between the shaft and retaining washer to allow the shafts to be "carefully" installed in the housing/bearings and cleverly using a 9/16 UNF for the retainer on the pulley end. Again, Excellent design, IMHO. The design reminded me of T-nuts for 80/20 or Bosch extrusions. I assume I'm right about using Round Bar to start with. Thanks again for sharing all this! ~PJ
Doug,
Thank you for your explanation for how you attached the spindle housing and still have the thickness of the retaining washer clear the spindle when the spindle is inserted.
Paul
Hi Doug,
Thanks for another great contribution! Your Tool Post Grinder is the 'Tool of the Week'!
As you've already received one of our official HomemadeTools.net T-shirts, we'd be glad to award you a $25 online gift card.
Just send me your email address via PM and we'll get things processed directly.
Congrats!
Ken
Congrats Doug! Well deserved! ~PJ
That makes 9 Tool of the Week wins for rossbotics. One more and we have our first 10-Time Tool of the Week award winner.
Here are all of rossbotics's 9 Tool of the Week wins:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/surface-gage-12175#post14591"><img src="/uploads/96960/height-and-square-gauge.jpeg" alt="Height and Square Gauge" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/surface-gage-12175#post14591">Height and Square Gauge</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags"> tags: <a href="/tag/gauge">gauge</a>, <a href="/tag/square">square</a>, <a href="/tag/dial-indicator">dial indicator</a>, <a href="/tag/height-gauge">height gauge</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/filing-machine-12989#post15657"><img src="/uploads/100104/filing-machine-3.jpeg" alt="Filing Machine" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/filing-machine-12989#post15657">Filing Machine</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags"> tags: <a href="/tag/file">file</a>, <a href="/tag/gunsmithing">gunsmithing</a>, <a href="/tag/motor">motor</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/slitting-saw-arbor-15838#post21004"><img src="/uploads/110216/slitting-saw-arbor-7.jpeg" alt="Slitting Saw Arbor" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/slitting-saw-arbor-15838#post21004">Slitting Saw Arbor</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags"> tags: <a href="/tag/machining">machining</a>, <a href="/tag/arbor">arbor</a>, <a href="/tag/slitting-saw">slitting saw</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/threading-insert-tool-holder-16929#post22973"><img src="https://www.homemadetools.net/uploads/139555/threading-insert-tool-holder.png" alt="Threading Insert Tool Holder" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/threading-insert-tool-holder-16929#post22973">Threading Insert Tool Holder</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags"> tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/tool-holder">tool holder</a>, <a href="/tag/threading">threading</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/tool-makers-vise-18400#post25623"><img src="https://www.homemadetools.net/uploads/118802/toolmaker-s-vise-2.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/tool-makers-vise-18400#post25623">Toolmaker's Vise</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags">tags: <a href="https://www.homemadetools.net/tag/vise">vise</a>, <a href="https://www.homemadetools.net/tag/machining">machining</a></div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/indexing-fixture-27750#post37609"><img src="https://www.homemadetools.net/uploads/129644/indexing-fixture-2.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/indexing-fixture-27750#post37609">Indexing Fixture</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags">tags: <a href="https://www.homemadetools.net/tag/gears">gears</a>, <a href="https://www.homemadetools.net/tag/indexing-unit">indexing unit</a>, <a href="https://www.homemadetools.net/tag/fixture">fixture</a></div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/r-8-modular-gear-cutter-arbor-29332#post40078"><img src="https://www.homemadetools.net/uploads/132398/gear-cutter-arbor-2.png" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/r-8-modular-gear-cutter-arbor-29332#post40078">Gear Cutter Arbor</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags">tags: <a href="https://www.homemadetools.net/tag/arbor">arbor</a>, <a href="https://www.homemadetools.net/tag/gears">gears</a>, <a href="https://www.homemadetools.net/tag/cutting-tool">cutting tool</a></div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/direct-indexing-sharpening-fixture-31319#post43293"><img src="https://www.homemadetools.net/uploads/136090/direct-indexing-sharpening-fixture.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/direct-indexing-sharpening-fixture-31319#post43293">Direct Indexing Sharpening Fixture</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags">tags: <a href="https://www.homemadetools.net/tag/sharpening">sharpening</a>, <a href="https://www.homemadetools.net/tag/fixture">fixture</a></div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/tool-post-grinder-33437#post46937"><img src="https://www.homemadetools.net/uploads/139267/tool-post-grinder-16.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/tool-post-grinder-33437#post46937">Tool Post Grinder</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div> <div class="tags">tags: <a href="https://www.homemadetools.net/tag/grinder">grinder</a>, <a href="https://www.homemadetools.net/tag/pulley">pulley</a>, <a href="https://www.homemadetools.net/tag/tool-post">tool post</a></div> </div> </div> </div>
From Canada
Nicely done and documented. I am always looking for ways :-) and means.
Bob
Now I know what my next project will be. Really nice work and thanks for posting!
Very nice design, I've been thinking about building one for some time now. So I've been studying the drawings, and am a little confused about a couple of things. In looking at the Grinder Base drawing, I see the dimension between the two holes that attach the Base to the Spindle Housing to be 1.250", but the Spindle Housing drawing shows the dimension to be .750 inches. The second thing confusing me is the Spindle Housing drawing shows the Base attaching close to one end of the housing, yet the pictures appear to show the base attached to the middle of the housing. Since the motor specs show the motor to be about 6" long, I could see the motor having to be attached toward the front end in order for the pulleys to line up at the back end.
Could there have been a design change between the drawings and the actual finished grinder? Is the spindle housing longer than 6 inches?
I only bring this up in case someone builds this from the plans and things don't line up right.
Thanks a lot for the design, it helps a lot in my thinking process, Steve
Very nice design. What I'm most interested in however is a source of high speed flat belts. I went to the source you quoted for the flat belt, but only found variations of v belts. I have used poly belts, but they are too flexible for higher speeds. Could you give us a bit more information on the belt you used?
Thanks, Steve
