Remove advertisements
Results 1 to 4 of 4
Thread: Torches and Begining of forge
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    Here are my torches and the start of my forge.Torches run clean and hot. Still gotta line forge with fire brick and 3/4" ceramic fiber board rated at 2300 degrees. The forge will be mounted on a 2x4 foot table that will raise and lower with an actuator control.
    Torches and Begining of forge-2018-05-22-19-21-57-1-.jpgTorches and Begining of forge-2018-05-22-19-26-43-3-.jpgTorches and Begining of forge-torches-1-1-.jpg
  2. The Following 10 Users Say Thank You to Bevoblood For This Useful Post:
    bukwessul (09-26-2018), Jon (05-22-2018), Paul Jones (05-24-2018), PJs (05-23-2018), rlm98253 (05-23-2018), rossbotics (05-24-2018), Seedtick (05-23-2018), sossol (05-23-2018), TO53 (09-29-2018), Tuomas (05-23-2018)
    garage nut's Avatar
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    Are the torches commercial or DIY?
    May 2018
    Elgin, Tx
    Bevoblood's Tools
    They are DIY garage nut. Made out of plumbing fittings 1" pipe, reducer, bracket is from scrap metal, the tubing into the pipe is a piece of 1/4" pipe hand threaded so I can run the plate up and down to change the way the oxygen is supplied to the torch. The end is a piece of 2" and the adapter weld to it for 1" pipe it is a tank adapter. Most everything came from McMaster Carr. the reducers were machined out inside to help with oxygen flow instead of have rough threads which does interrupt the flow.
  5. The Following User Says Thank You to Bevoblood For This Useful Post:
    Sleykin (05-24-2018)
    Content Editor DIYer's Avatar
    Thanks Bevoblood! We've added your Forge Burner to our Heating and Cooling category,
    as well as to your builder page: Bevoblood's Homemade Tools. Your receipt:
    Post your reply!
