Translating Total Feed Rate to A Axis RPMs and X/Y axis Feed Rates
If you are not into CNC, this article may make no sense to you at all. Actually, if you are into CNC, it still might not make much sense :)
This article explains how to take the feed rate for a cutter and translate it into the correct RPM for rotating an A axis plus the correct X axis feed rate that gets you the desired radial depth of cut.
http://rick.sparber.org/TTFR.pdf
