Results 1 to 4 of 4
Thread: Tuyeres
    Carpenter & blacksmith Philip Davies's Avatar
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Tuyeres
    I have used this type of tuyere for several years, although itís not usually going for more than a couple of hours, and the fuel is charcoal. It is a bottom blast, supported on bars below a layer of ordinary Victorian house bricks. So long as the air flow is continuous, it does not block up. The stop end can simply be unscrewed if ash accumulates, but I donít usually need to do this while forging. I have also used coke. Charcoal produces very little slag. The benefit of an old sledge hammer head is that slag does not stick to it, even using coke.
    Now I want to experiment using a side blast, which is why this tuyere has no stop end.
    A note of caution. To fit the pipe to the hammer eye, I had to heat it. It is better not to use galvanised pipe, because of zinc fumes-which can kill! The tubes are not galvanised, although they appear to be, in these pictures.
  2. The Following 4 Users Say Thank You to Philip Davies For This Useful Post:
    EnginePaul (12-17-2018), Jon (12-12-2018), PJs (12-13-2018), rlm98253 (12-12-2018)
    Sep 2015
    Sandy, OR
    Whats a tuyere?
  4. The Following User Says Thank You to mudnducs For This Useful Post:
    Dec 2015
    Reading, Berks, UK
    It is a tube into a forge or furnace through which air passes, which makes the fire burn hotter. The air is forced, using bellows, or an air pump.
  6. The Following 3 Users Say Thank You to Philip Davies For This Useful Post:
    Andyt (12-13-2018), PJs (12-13-2018), Toolmaker51 (12-12-2018)
    Content Editor DIYer's Avatar
    Thanks Philip Davies! We've added your Tuyere to our Forging and Casting category,
    Post your reply!
