Remove advertisements
Results 1 to 10 of 20
Thread: v belts
    Nov 2015
    v belts
    would a 10 mm width v belt be strong enough for a 2300 watt motor (approx 3hp)?
  2. The Following User Says Thank You to jonnydot For This Useful Post:
    Seedtick (09-18-2018)
    rossbotics rossbotics's Avatar
    Dec 2013
    Florida
    rossbotics's Tools
    Depends on how much torque your putting on it, what are you driving with it?
    Doug
    Comments are always welcome
    Doug
    Nov 2015
    I purchased this unit for the motor https://www.ebay.com.au/itm/Giantz-2...53.m2749.l2649
    Nov 2015
    I don't know the rpm so I cannot work out the torque
    Dec 2013
    Florida
    rossbotics's Tools
    Ok, then what are you planning to do with it? make a grinder ? Etc.
    Doug
    Doug
    Nov 2015
    Quote Originally Posted by rossbotics View Post
    Doug
    Oscillating spindle sander https://www.dropbox.com/s/nh359qla57...ander.pdf?dl=0
  8. #7
    Frank S's Avatar
    Like Doug said a lot depends on the application, plus the driving pulley diameter sped reduction ratio IE the driven pulley diameter divided by the driving pulley center distances will it be a continuous load drawing full rated wattage or varying loads.
    If your loading is intermittent rarely requiring full power and the small pulley is the driving pulley at least 7 times in diameter of the width of the belt then
    the short answer would be probably, but in general the short answer would be not quite.
    And if the driving pulley diameter is to be less than 7 times the width of the belt or the driven pulley is smaller than the driving then the short answer would be no
    These belt selection guides may help you out
    https://www.baldor.com/mvc/DownloadCenter/Files/MS4050
    https://www.allworldmachinery.com/im...DESIGN_MAN.pdf
    PJs (09-23-2018)
  10. #8
    Frank S's Avatar
    Ok, your sander is going to have yet another factor that comes into play unless the shaft is going to be splined so you can allow the shaft to travel freely up and down without the pulley moving, you are going to have to run your belt slightly loose due to the vertical movement of the shaft the sanding drum will be mounted on plus you will most likely want the drum spinning faster than the motor unless the motor RPM is at least 3600 RPM.
    This will mean you will want a reasonably long center distance. the 2 guides I previously posted should have a section for maximum allowable pulley misalignment angle. you will need to factor that equation into your power factor equation.
    However in your machine design the limiting factor is not going to be the design hp of the belt but the shaft diameter. with the 20 mm shaft you could get away with a 500 to 1500 watt motor. Since you may already have the 2300 watt motor I'd say run with it just be sure that the pulley on the shaft is between 2 bearings located as near as possible to both vertical limits of the shaft movement even if you have to add a 3rd bearing
  11. #9
    milomilo's Avatar
    Dec 2014
    I think you need at the least a 5/8" wide belt.
    Chris
  12. #10
    Toolmaker51's Avatar
    Is this the place to ask whatever or what! Some stellar posters have already joined in to guide your quest.
    I'll offer a page https://cse.google.com/cse?cx=partne...generic..0.0.0.
    That's the Engineering Toolbox, info on anything anyone can imagine....https://www.engineeringtoolbox.com/
    And here, ~ 7,370,000 results in googling "determine RPM of electric motor"....... https://www.google.com/search?q=dete...nt=firefox-b-1
  13. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    philipUsesWood&Brass (09-19-2018), PJs (09-23-2018)
