Results 1 to 7 of 7
Thread: Vises, Parallels & Springs...
    Many ways can retain parallels in a vise set-up. Normally the idea is they are supported during part changes, plus keeping swarf from getting underneath.
    I commonly retain them with an arched spring, using steel tape found on palletized shipments.
    Common sizes are 1/2", 3/4" and 1" wide, add a couple leaves when more pressure is required.
    Notice the trick for sawn material, to avoid the burr at the lower edges.
    Narrower parallels on the outside give plenty of burr clearance. Saves a lot of time in multiple parts, first off by saving at least one de-burr on each.
  2. The Following 13 Users Say Thank You to Toolmaker51 For This Useful Post:
    Crusty (May 29, 2020), davesrepair (Apr 1, 2024), EnginePaul (Mar 22, 2018), FEM2008 (May 28, 2020), Home-PC (Feb 12, 2023), JD62 (Mar 19, 2018), Jon (Mar 19, 2018), metric_taper (Mar 19, 2018), oldcaptainrusty (Mar 21, 2018), olderdan (Mar 19, 2018), Philip Davies (Jun 29, 2020), PJs (Mar 19, 2018), Seedtick (Mar 19, 2018)
    Berkshire UK
    thehomeengineer's Tools
    Hi Toolmaker51
    Another great idea, really like it
    thank you for sharing
    The Home Engineer
  4. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Toolmaker51 (May 28, 2020)
    Thanks Toolmaker51! We've added your Vise Spring to our Vises category,
    Jul 2019
    Ohio, USA
    Brilliant! I was just hunting down some longer rubber bands to hold the parallels, but this is even better. I always keep a piece of band steel around. Thank you.
  7. The Following User Says Thank You to FEM2008 For This Useful Post:
    Dry Gulch, Tx
    Crusty's Tools
    Save the steel banding from crated shipments. It can be used to make disposable custom leaf springs in a jiffy for such purposes.
    We all save small springs, but re-use is rarely out side of it's original ability. Re-use of steel banding might be one of my first re-utilization hacks. All kinds of applications, the newer plastic type can be too.
    I'm finishing cleaning up CL find of outfeed roller stands, they were sorely neglected. But three of them @ 1/3 price of one new, who could resist? Apparently quite a few, been up a long time, according to seller. Anyway, they have a 1/2" -13 clamp screw. Looking for 1-1/2 banding, typical on shipments of structural steel, for a buffer between screw and the adjustable column.
  10. #7
    Quote Originally Posted by FEM2008 View Post
    Yes. A lot of people use rubber bands; but some cutting compounds deteriorate them fast. Worse yet some get gummy,requiring solvent to remove.
