Dan,
I have only just seen your message. I haven't yet figured out how to keep track of comments on my posts yet. This is the only forum that I am active on, so there is still much to learn.
I know that many people do as you have, that is machine the shoes a little undersize. The problem with that approach is that the shoes don't have the same curvature as the drum until they have worn a bit. That contributes to spunginess.
What I do is, shim the shoes out from the cams and then machine the shoes to drum size. Then with the shims removed the backplate/shoe assembly will fit and when the brake is applied the shoes and drum will match. I use an expanding mandrel to hold the back plate when machining the shoes to ensure concentricity.
Another thing that I do differently from the norm is to do with the cam lever actuation. The norm is to have a rigid adjustable rod between the two levers as you have done. Getting that adjustment spot on for equal pressure on each shoe is not easy and any error will cause spunginess also. I can't take credit for an alternative method because I first saw it on the Earles forked BMWs that I had in the 1960s. As soon as I saw it I saw how clever it was and it made perfect sense. You have the outer cable connected to one of the cam levers (instead of fixed to the backplate) and the inner cable to the other cam lever. Now the force on the two levers is balanced. This method demands that the cams are symmetrical, or else designed for the job, because it will be the outer edge of one cam that operates the shoe and the inner edge of the other cam. That lack of symmetry slightly changes the leverage on the shoe for a given torque on the external cam lever. That imbalance is not too important but can easily be fixed by making the two cam levers with slightly different lengths. IIRC BMW used equal length levers but I make the correction with different lengths.
I hope that convoluted explanation makes sense. I'll try and dig up some sketches or photos. Otherwise Mr Google may know about it.
PS. The full cable force is applied to each cam lever, whereas the rigid rod system has to share the application force between the two. So for equal lever lengths on the two systems, the rigid rod system will brake less for a given cable force. However, there are two sides to leverage - force and displacement. Although the cable only system produces more force on the cam levers it does this at the expense of double overall cable movement, so it will feel more powerful but also more spungy, the answer to this is to shorten the cam actuation levers to return to the original overall leverage.
