Results 1 to 6 of 6
Thread: Wire Bending Tool...Quick and Cheap
    jjr2001's Tools
    Put this little wire bender together for model airplane landing gear. It was made from stuff in the scrap box.
    Really could use some finishing touches but then it would not be quick.
    One bolt is used for the end rod and that has a small radius around the shaft to hold the wire while the arm is rotated on it. The wire is picked up by the radiused allen cap screw on the arm and then rotated until it has the desired bend against the radiused allen on the steel bar. Works fine for upto 5/32 music wire.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Wire Bending Tool...Quick and Cheap-dscf0009.jpg   Wire Bending Tool...Quick and Cheap-dscf0010.jpg   Wire Bending Tool...Quick and Cheap-dscf0011.jpg   Wire Bending Tool...Quick and Cheap-dscf0012a.jpg   Wire Bending Tool...Quick and Cheap-dscf0013.jpg
  2. The Following 5 Users Say Thank You to jjr2001 For This Useful Post:
    emu roo (Apr 2, 2023), Paul Jones (Jan 22, 2017), penca (Jan 26, 2017), PJs (Jan 22, 2017), rlm98253 (Jan 25, 2017)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Down and dirty but look like it works great. Like that you put the radii on the pins. Does the inboard one rotate with the wire?
    Mark Twain
  4. The Following 2 Users Say Thank You to PJs For This Useful Post:
    jjr2001 (Jan 22, 2017), penca (Jan 26, 2017)
    jjr2001's Tools
    No rotation of the pins, just the lever. I need to clean it up and make up more pins for various sizes of wire for future use. I use 1/8 5/32 and 3/32 mostly. I have one longer pivot that will make coils if I need that on the landing gear.
    Cheers, JR
  6. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    Paul Jones (Jan 25, 2017), PJs (Jan 23, 2017)
    Thanks jjr2001! We've added your Wire Bender to our Metalworking category,
    Supporting Member penca's Avatar
    Apr 2013
    penca's Tools
    great tool man, thanks for sharing
    pete
  9. The Following User Says Thank You to penca For This Useful Post:
    jjr2001 (Jan 26, 2017)
  10. #6
    jjr2001's Tools
    Thank You Penca, my pleasure to post.
    Cheers, JR
