Woodturning tool rest, medium and small size
Hi,
You know what ?
I have a brand new wood lathe !
It has much more capacity compared to my old Chinese one.
So it is an opportunity to build plenty of new tools, especially the tool rests and steady rest I had will have to be re-done or adapted because it is no more compatible.
This one has a 30 mm diameter post for the tool rest (this is quite big), so here is a series of new tool rests.
First I present a couple of standard shape rests. The only one delivered with the lathe is 350mm wide (huge), so I made a 200 mm and a 150 mm for smaller pieces.
http://www.labellenote.fr/file/homem...l_Rest_009.JPG
http://www.labellenote.fr/file/homem...l_Rest_004.JPG
The build is rather straight forward, the post is trued on the metal lathe for the bottom side, and the other side is cut at 45° with a big angle grinder. One cut makes two posts at 45°, it's the reason why I made two of them. The top piece is a big piece of flat steel, cut at 45° and MIG welded.
(My weld is quite hugly, I know ...:sweating: )
