I made this mini tool post grinder from a Harbor Freight micro pencil grinder and some scrap aluminum.
https://youtu.be/ARIWtNNTi44
Thanks Welcome to the Machine! We've added your Tool Post Grinder to our Machining category,
as well as to your builder page: Welcome to the Machine's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-tool-post-grinder-34"> <img src="/uploads/223458/homemade-tool-post-grinder-34.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-tool-post-grinder-34">Tool Post Grinder</a> <span> by <a href="http://www.homemadetools.net/builder/Welcome+to+the+Machine">Welcome to the Machine</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/grinder'>grinder</a>, <a href='http://www.homemadetools.net/tag/tool-post'>tool post</a> </div> </div> </div> </div>
Pretty typical of the runout on those pencil grinders, the collets aren't very precision.
A careful whack and a diamond truing of the wheel will help out a lot to get a good finish.
I've done similar grinding by just putting the grinder in the toolpost directly. and carefully tightening the setscrews down on the grinder body.
Not precision grinding just a gotta get it done job.
Good job.
I use the same type of grinder in a boring bar holder, sleeved to suit the diameter of the body, for sharpening end mills in the lathe.
