Excellent solution for your application and purposes Christophe. That happens to be the reason why I have a need for an indexing plate in my lathe. But there's more than that to justify it. Consider this; it is a known fact that is always easier to find and keep a center in a lathe than in a mill if you have one. Accordingly, before moving the part to the mill to continue processing, I use the index plate to locate radially disposed holes in the work piece drilled with a 1/8" (3.175 mm) hole and later transferred to my rotary table and using a pin gauge held in the mill chuck, I locate one hole and then all the others in succession to be enlarged as needed accurately and easily.
Regards
Jorge
Christophe,
This is another example of your well designed, documented and photographed projects. There are many ideas here I want to "borrow". The combination of wood and metal by adding your custom turned beech crank knob is a nice touch.
Thank you for posting, Paul
Very nice idea !
It's a very nice idea, I wanted to make an index plate and a crank, you are doing both in one tool.
Please could you tell us the diameter of the plate ?
Bonsoir Yves,
The plate has a 236mm diameter. It was purchased at "Géant Casino", kitchen department, it's an induction interface, ~20€.
Bonjour Christophe,
Thanks a lot. I did'nt dare to ask you were it was going from, but it was also a question for me !
I'm just a regular looker. Lots of great ideas.
Thanks, Dave
Congratulations Christophe Mineau, your Indexing Plate and Crank is our Tool of the Week!
Please PM me your email address, and we'll send along a $25 gift card, via your choice of PayPal, Amazon.com, GiftRocket, or bitcoin.
And that makes 8 Tool of the Week wins for Christophe Mineau! :rocker:
Here they all are:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/carving-platform-12404#post14854"><img src="/uploads/97684/carving-platform-2.jpeg" alt="Carving Platform"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/carving-platform-12404#post14854">Carving Platform</a>
<span> by <a href="/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<div class="tags">tags: <a href="/tag/table">table</a>, <a href="/tag/holding">holding</a>, <a href="/tag/platform">platform</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/spokeshave-14454#post18351"><img src="/uploads/104721/spokeshave-3.jpeg" alt="Spokeshave"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/spokeshave-14454#post18351">Spokeshave</a>
</div>
<div class="tags">tags: <a href="/tag/hand-tools">hand tools</a>, <a href="/tag/spokeshave">spokeshave</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/my-disk-sander-built-15224#post19785"><img src="/uploads/107731/disc-sander-38.jpeg" alt="Disc Sander"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/my-disk-sander-built-15224#post19785">Disc Sander</a>
</div>
<div class="tags">tags: <a href="/tag/disc-sander">disc sander</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/my-engraver-vice-bowl-vise-16590#post22327"><img src="/uploads/112090/engraver-s-bowl-vise.jpeg" alt="Engraver\'s Bowl Vise"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/my-engraver-vice-bowl-vise-16590#post22327">Engraver's Bowl Vise</a>
</div>
<div class="tags">tags: <a href="/tag/vise">vise</a>, <a href="/tag/engraver">engraver</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/m-shape-bridge-wood-feeding-table-saw-19064#post26711"><img src="/uploads/121694/push-block-6.jpeg" alt="Push Block"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/m-shape-bridge-wood-feeding-table-saw-19064#post26711">Push Block</a>
</div>
<div class="tags">tags: <a href="/tag/safety">safety</a>, <a href="/tag/table-saw">table saw</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/lathe-tailstock-quill-extension-index-30784#post42449"><img src="/uploads/135146/tailstock-depth-indicator.jpeg" alt="Tailstock Depth Indicator"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/lathe-tailstock-quill-extension-index-30784#post42449">Tailstock Depth Indicator</a>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/tailstock">tailstock</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/%5Bwoodworking%5Dscratch-stock-36909#post51092"><img src="/uploads/237391/homemade-beading-tool-5.jpeg" alt="Beading Tool"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/%5Bwoodworking%5Dscratch-stock-36909#post51092">Beading Tool</a>
</div>
<div class="tags">tags: <a href="/tag/wood">wood</a>, <a href="/tag/beading">beading</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/%5Bmetal-lathe%5D-indexing-plate-cranck-41391#post59606">
<img src="/uploads/146971/indexing-plate-and-crank.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/%5Bmetal-lathe%5D-indexing-plate-cranck-41391#post59606">Indexing Plate and Crank</a>
<span> by <a href="https://www.homemadetools.net/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<a href='https://www.homemadetools.net/tag/indexing-unit'>indexing unit</a> </div>
</div>
</div>
</div>
Congratulations Christophe!
A well deserved award, but I saw this one coming :)
Well, thank you Jon !
I'm greatly honored, and very happy indeed .
This is a really a useful tool, since I've made it, I 've used it already several times and I wonder how I didn't make it earlier...
Thanks again, and thanks also to all, for your encouraging comments !
I take the opportunity to tell all the "readers only" to take the step and start posting what you do, no need for complicated or intricate tool, sometimes the simplest are the most useful and can be worthwhile to be shared !
Cheers !
Christophe
Congratulations Christophe, a well deserved Award for a useful, simple & elegant build with recycled materials! Doesn't get much better than this in my book! Your award "Bling" and "builds" are most impressive, something to strive for and so fitting for HMT!
:clapping::thumbsup::bow: ~PJ :hattip:
