[Woodwind] Tone hole Cutter
Hi !
Here is a very specific tool made for shaping the top of a tone hole chimney.
This is for tone holes that will be covered by a key. It is crucial that the pad of the key has a neat contact with the wood in order to avoid any leakage.
The contact surface is actually reduced to a single ring if the tone hole has a slightly spherical top.
Here is what we want to obtain :
http://www.labellenote.fr/file/homem..._tool_0010.jpg
And here is how it is done :
First, a guiding pin is turned down, given the diameter of the tone hole.
And then a custom ground shaping tool is used to cut the spherical shape of what will be the cutting edge.
http://www.labellenote.fr/file/homem..._tool_0001.jpg
Then I use my milling attachment to drill 6 transversal flat bottom holes with a small carbide end mill cutter.
http://www.labellenote.fr/file/homem..._tool_0002.jpg
This will form cutting teeth
http://www.labellenote.fr/file/homem..._tool_0003.jpg
http://www.labellenote.fr/file/homem..._tool_0004.jpg
Then I use a cutting disk on a Dremel to grind down the back of each tooth.
http://www.labellenote.fr/file/homem..._tool_0005.jpg
http://www.labellenote.fr/file/homem..._tool_0006.jpg
Here I'm using my transversal drilling attachment on the lathe with this tool.
http://www.labellenote.fr/file/homem..._tool_0007.jpg
Close up
http://www.labellenote.fr/file/homem..._tool_0008.jpg
http://www.labellenote.fr/file/homem..._tool_0009.jpg
Finished Job
