Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: 1 HP 2" Belt Sander
    Oct 2018
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I Like this Build.... Awesome
  2. The Following User Says Thank You to Phil.rvc For This Useful Post:
    tekcraft (11-20-2019)
  3. #12
    Aug 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wizard69's Tools
    Quote Originally Posted by Chadboye View Post
    Thanks so much, that really helps me alot!! I really want to build a 2x72 grinder but I'm thinking that a 2x48 like yours would be alot better for me right now, plus I'm very limited on space in my tiny little shop in my basement.
    You can do the same general layout for a 2x72. The distance between centers becomes something less than 36, depending of course on your roller diameters. Use larger diameter rollers to get better belt traction and better tracking.
    like you shop space is limited at the moment! So Ive been thinking of going this route for a simple belt grinder. I bought a 1x72 grizzly that isnt worth the time and money invested in it which is a motivator here. Most shops have the vertical space to handle something 36 tall. The other advantage of a 72 belt Id that the work table can be placed above the motor and you still have room for a backer and slack ( somewhat) belt grinding.
    if I go this route the other advantage is that a more complex grinder would likely use the same belts. In any event just some ideas to chew on.
  4. The Following User Says Thank You to wizard69 For This Useful Post:
  5. #13
    Aug 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wizard69's Tools
    Tekcraft
    Even on my cell phone this looks like a quality build set to last many lifetimes. Nice work!
    this also highlights the need to fix my laptop.
  6. The Following User Says Thank You to wizard69 For This Useful Post:
  7. #14
    tekcraft's Avatar
    Jan 2015
    Coal Valley, IL
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    tekcraft's Tools
    Thanks for the positive comments. I don't know what advantage having a 72" belt would give. The 48" belt is a lot less expensive and I have a solid backer and plenty of slack for edge deburring.
    Good luck with your build.
    Post your reply!
    Join 42,532 of us and get 200+ tool plans, tool eBooks, build guides, and much more.
    eBooks for Supporters
